Computer on desktop th mouse wouldnt move the Cursor I shut down the computer an re started.It rebotted to F1 to continue or F2 to set up.it said it was in safe mode.It was then i found the Key board was not working.I took the keyboard an mouse off my Emachine T5026 which was working Fine an installed it on my T3418 an it was no difference the T3418 was still stuck in Doss an the mouse an Key board were not working.I re installed the mouse an Key board Back on my T5026 an the worked Finemy wife is in a panic as she has years of Family Tree an ancestry on that computer that is lost now Any help would be Appreciated Paul Williamson
    Genius:
  • 1,035 Answers
Hi. Are you using a USB keyboard on your computer? Try to plugged in the keyboard with other USB port including the mouse also. Does your computer boot up to windows?
Posted on Oct 09, 2010
Unable to move cursor on lenovo x61
Are you trying to move the cursor with the trackpoint, a usb mouse, or the pen? Have you tried restarting your computer? Restarting would likely solve the problem. If you can't move the cursor to the start menu, you can open the start menu with the windows key, use the arrow keys to navigate to the power options. Use enter to select the power options and shut down or restart the computer. If this does not work, press and hold the power button for 5 or 10 seconds to force the computer to shut down.
What happened before this occurred? Did you install any programs or updates recently, or change any settings on your computer?
Apr 12, 2015 | Lenovo ThinkPad X61 Tablet PC
Power Supply
You can't start the computer remotely. The computer can start remotely if the BIOS is set to "allow Network devices to start computer" or similar actions. When the computer is booting up, usually you'll see an option to press F1, F2, Del, or another key to enter the BIOS. Make sure the settings are saved as you exit.
If the computer is in Sleep mode, just moving the mouse, or pressing a key could wake it. In that case, lock the cat out of the computer room.
Nov 16, 2013 | HP Compaq dc5100 PC Desktop
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
THE CURSOR WONT MOVE WHEN YOU ROLL THE MOUSE CANT CLOSE WINDOWS DOWN
Hold in the main power on button until the computer shuts down -windows will automaticly safley shut down .
once it shuts down restart it and hopefully the mouse problem will also be fixed
I hope this helps
Andrew a
Mar 28, 2011 | Computers & Internet
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Apr 17, 2010 | Dell Dimension 4700 PC Desktop
Computer wont boot up
first reconnect your keybord and mouse jack in computer then power up the compter then press del or F1 or F2 to nweter in bios setup then just press F10 and save settings .
Feb 07, 2009 | Dell Computers & Internet
My computer won't start up right
press F1, when it boots you are going to have to go down to the date and time, and click on it then you will need to put in the correct day date and time. If pressing f2 it will take you into the bios, and you can set it from there prior to booting, unless you know what you are doing, stay away from the bios, it can really screw up your computer. Good luck and Peace,Gym
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Mouse Cursor Frozen
Try putting the computer into safe mode by shutting down the computer. Turn the computer back on. At beginning of the boot process press and hold the f8 button and select safe mode from the menu.
When the safe mode is done booting up, try moving the mouse around. If it works, restart the the computer under normal Windows startup procedures.
Jun 13, 2008 | E-Machines eMachines Desktop PC
Suddenly the cursor moves back to a previous line and continues typing making a joke of what I'pingm typing (see it just did it)
make sure the mouse cursor is further down the page from where you are typing. If your text continues over the arrow of the cursor and any static electricity or touch is detected by the glide pad of a laptop or S.E. from a mouse it will move the text cursor to where the mouse cursor is.
This is a continual problem with sensitive computers.
sorry there is no permanent "FIX"
Jun 04, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
