Question about Bosch 24 in. PIE675T01E Electric Cooktop
Bosch ceramic hob
When i try to switch on the hob a red padlock symbol appears. Have i somehow locked the hob, a safety feature perhaps. cant find my manual !!!
  • 5 more comments
  • Anna Jun 28, 2008
    I have the same problem with my PIF645 ceramic top - the hob is locked and a padlock symbol appears
  • warda9 Sep 28, 2008
    my hob wont switch on at all.???????
    Please help
  • Anonymous Oct 15, 2008
    My bosch PKN791E02E ceramic hob won't switch on at all. the padlock symbol is displayed. how can i turn it back on?
  • john crowder
    john crowder Dec 24, 2013
    i switched of at mains for 5 minutes then on and kept finger on on / off button, and it started to work after about 5 seconds. thanks.
  • Anonymous Mar 12, 2014
    Candy CH64C Ceramic Electric Hob - Black locked the four ring
    Candy CH64C Ceramic Electric Hob locked the four ring
  • Anonymous Mar 22, 2014
    my ceramic hob switch on and off frequently(almost every two seconds) with clicks when I use it on. four stoves have the same problem. does any body know the reason or solution?
Hold down powerboot for 4 seconds to switch off child lock
Posted on Sep 15, 2008
  • deepa May 10, 2013
    Hold down the lock button for few seconds..... it worked for me...
  • Giota P Jun 30, 2013
    I switch off child lock by holding my finger on the touch pad but when I try to turn on the hod child lock comes again. THis has been all day long.. It is so frustrating. Is there a way to totally disable this feature?
UNLOCK THE LOCK OF CHILDREN IN CERAMIC
Hi and welcome to FixYa,
I can not insert the symbols here to properly answer your question so, I found the manual and you can read the steps on page 9 here:
http://awadnahas.net/pdf/UserManual/bf7e9e9b-cc9e-46fc-94a7-5965a2d61b18.pdf
This is copy and paste from the manual and the symbols will not come out:
Switching off the child safety device
• Start the hob with ( ' ). Do not set the heat settings . Touch for (Up arrow) 4 seconds. The
symbol ( 0 ) comes on.
• Stop the hob with ( I )
The symbols I typed above are not 100% as they appear in the manual.
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | AEG HK955070CB 41 in. Electric Cooktop
When I switch on, there is a pad lock symbol that gets displayed and I can't turn up the heating elements.
Thank you for using FixYa. The pad lock symbol is a child safety device to prevent accidental operation. Press or touch the area on or around the padlock symbol and the indicator will go out and thus allow you to use the hob
Mar 04, 2011 | Bosch 24 in. PIE675T01E Electric Cooktop
How do I turn the childproof red padlock light off on my Bosch Ceran hob?
find the button that has a lock on it or beside it, push it in and hold it until it unlocks
Jan 18, 2011 | Bosch 24 in. PIE675T01E Electric Cooktop
Hob is locked
Press the 'Oven light' for about seven seconds...
Jun 06, 2009 | Bosch 24 in. PIE675T01E Electric Cooktop
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob. I also have the red key about the on switch and cannot swithc it on!
hi gud day, more of ceramic hob is touch control,try to stay ur thumbmark wen the unlock circle to unlock if u hear the sound it means is unlock also in the other wat u want to operate,or clean the surface coz some oil is coz of not operate properly. tnx gerbee
May 28, 2009 | Neff 23 in. T4343 Electric Cooktop
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Padlock sybol when try to turn on hob
Jan 12, 2009 | Bosch 32 in. PIE875T01E Electric Cooktop
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Bosch 24 in. PIE675T01E Electric Cooktop Logo
4,497 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
