Question about Whirlpool Dryers
Convett my whirlpool gas dryer to vent from the side
    Novelist:
  • 177 Answers
Whirlpool makes a kit for this, however since you have a gas dryer, you will not be able to vent out the side the gas heater is on.
Take the front panel off and look for the gas valve it should be on the left side, if you need to vent out on the left side you will not be able too.
Posted on May 31, 2008
On whirlpool LG5201XTWOThe dryer wont heat-it over 5 hrs to dry a load. it would not turn off on automatic side & just keeps running. it turned off on the timed side
The clothes are not drying than usually means a venting problem, the vent needs to be clear and no sags to collect moisture also, as short and straight as possible.
Jan 20, 2014 | Whirlpool GGW9200L Gas Dryer
I have a Whirlpool Calypso gas dryer, vented in the back. Can the venting be changed to vent out the side?
some dryers have a round "knockout" on either side which would allow for different venting options. You also need to check the ducting inside the machine to determine if it can be re routed without causing a sharp bend or kink that would cause over heating and lower efficiency.
Apr 30, 2011 | Whirlpool Dryers
Whirlpool gas dryer LGR6636PWO heats for appro. 5 minutes & quits heating but still runs.
First check the exhaust vent and connecting vent material for a clog. If vent is OK,replace the gas valve coils.
Oct 04, 2009 | Whirlpool LGR6636 Gas Dryer
Whirlpool flames on for a few cycles, then no flame,, all therostats have continuity,dryer keeps running on auto dry, tested gas coils seem fine too any ideas?
if you have tested your gas coils then i would probably check your exhaust venting. May be plugged with lint build up...if the vent comes out the side of the house go round the house and see if you have good air flow comming out....hope this helps
Jul 29, 2009 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool gold Ultimate Care II gas dryer and 2/3 times the ignitor glows and lights the gas, 1/3 times it won't. When the gas does light, it doesn't seem like it's getting hot enough to do...
I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Mar 26, 2009 | Whirlpool Dryers
Gas Dryer - takes to long to dry
Friend,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.If the vent line is kinked or blocked
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
Take the vent line off the rear of the dryer and try if it works. If it does you know it's the vent line and not the dryer that's the problem the dryer.
You will be fine
Bless You huuum
Feb 01, 2009 | Whirlpool LGR3624JQ Gas Dryer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool gas dryer GGQ8858KQO won't heat
hi thanks for the question .the problem you have is with the thermal fuse. located at the back. remove back panel . on the air duct, on left side, you will see a small plastic piece, with 2 blue wires to it. replace this part. and clean all air venting to the outside. as dirty vents can cause the thermal fuse to fail. thanks the appliance doc
Sep 29, 2008 | Whirlpool LGQ9858PG Gas Dryer
Steam comes out of dryer after cycle and door is opened
Probably has a restricted vent. Go outside with dryer running and check air coming out vent. Should be a good blast...not just a breath. Clean out the vent and make sure it's not kinked. If it vinyl or foil vent, replace it! Also make sure lint screen is cleaned everytime.
Nov 16, 2007 | Whirlpool LGR3624JQ Gas Dryer
Open Questions:
Dryers Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
