Question about Vivitar 283 Flash
The hotshoe foot on my Vivitar DF-383 flash unit is broken. Where can get a replacement part?
    Problem Solver:
  • 8 Answers
Don't buy anything before you shop the bay and craiglook.com (don't put in a zip code) for another flash. Often a used flash is reasonably close to the price of a new part. Your flash may be worth the repair, I am not looking at it so I can't say.
If you want to get a part, and if the flash is a few years old, there will be broken models for sale everywhere. And Photo.net has a forum for everything related to cameras. I often get parts sent to me free even though I am willing to pay for them. Someone will have the part you need.
Other than that you can call the maker and ask if they will send you a part free. I am amazed by how many companies are willing to send free parts on things that should not have broken. It never hurts to ask.
Best wishes.
Posted on Oct 09, 2010
  • gatorman0073 Oct 09, 2010
    thanks ep..I understand from my googling it's a common problem..and the fix can be done at home with the correct instructions..finding the exact part is the key of course..I'm hoping Vivitar will come through for me..thanks again
I have a Nikon D 3100, and just bought a Vivitar DF 383. I made a streight on shot about 15 ft away in Auto mode, and the flash over powered the image. What do I need to look at first to correct this
Not really familiar with particular model but: if is not iTTL (or even if it is), try changing the power level of the output. Read your manual.
Mar 28, 2011 | Vivitar Cameras
Sunpack Compatibilty
ifyour nikon has a hotshoe it should work quite well. I use sunpak flash on both canon and olympus without any problems. Just connect to hotshoe and shoot.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Sunpak 383 Super Flash
Vivitar DF-283-CAN flash suddenly won't go off. I hear it power up and the ready and ettl lights go on but the ok light doesn't light up and the test button wont work either.I tried replacing the batteries...
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Jan 01, 2010 | Vivitar DF-200 Flash
Hot shoe plastic section broke on flash unit
I managed it by buying a broken (non-working) F32X from an auction service for something like 5 bucks. I just made sure (by looking at the photos) that the hotshoe was intact.
Here's how to disassemble and replace foot (I got to this by trial and luckily no error ^^).
  1. Unscrew 2 small screws located under the battery flip cover.
  2. Put the lamp (moving part) in the upright position.
  3. Unscrew 1 small screw above the infared sensor (below the main lamp part which you moved to the upright position).
  4. Remove the cover of the infared sensor by gently pulling forward.
  5. On two sides of the infared sensor there are two small clips which hold the 2 casing pieces together. Pull them away from the casing just a tiny bit and use something to keep them in this position (I used 2 small nails). Then pull the pieces apart gently.
  6. Just behind the hotshoe casing you can see a small plastic inset -- place a screwdriver sideways between this inset and the hotshoe to help you separate the two casing parts. Be careful when doing that, don't use too much force, wiggle the casing instead to make this easier (this is the most tricky part).
  7. When the electronics is exposed, there is a single screw in the middle of the motherboard. Remove the screw and gently pull the motherboard away from the casing. You do not have to pull it all the way or disconnect any cables, you just need to make sure the bottom battery connectors are pulled out of the casing just a little, because then under the two middle battery connectors (looking from the top, as if you were putting the batteries in) you can see two screws!
  8. Unscrew those two screws, and the hotshoe will come apart. Pull it out gently and remove a single electrical connector that connects it to the flash.
Do this in case of your working lamp (with a broken hotshoe) and your replacement lamp (with a good hotshoe), and just move the good hotshoe to your working lamp.
Took me about an hour to do this (most time was spent on trying to figure out how to disassemble the lamp), and the lamp works perfectly.
Warning: better test disassembly on the replacement lamp, since even if you break it, all you need it for is the hotshoe, so you can practice on it. Only after you learn how to disassemble the F32X do this on your working lamp.
Hope this helps!
-- Tomasz Andrzej Nidecki (tonid)
Jun 17, 2009 | Sony HVL-F32X TTL Flash
Sony hvl-f32x
  5. On two sides of the infared sensor there are two small clips which hold the 2 casing pieces together. Then pull the pieces apart gently. Just behind the hotshoe casing you can see a small plastic inset -- place a screwdriver sideways between this inset and the hotshoe to help you separate the two casing parts. Be careful when doing that, don't use too much force, wiggle the casing instead to make this easier (this is the most tricky part).
  6. When the electronics is exposed, there is a single screw in the middle of the motherboard. Remove the screw and gently pull the motherboard away from the casing. You do not have to pull it all the way or disconnect any cables, you just need to make sure the bottom battery connectors are pulled out of the casing just a little, because then under the two middle battery connectors (looking from the top, as if you were putting the batteries in) you can see two screws!
  7. Unscrew those two screws, and the hotshoe will come apart. Pull it out gently and remove a single electrical connector that connects it to the flash.
  8. Do this in case of your working lamp (with a broken hotshoe) and your replacement lamp (with a good hotshoe), and just move the good hotshoe to your working lamp.
Hope this helps!
Feb 05, 2009 | Sony HVL-F32X TTL Flash
Broken Hot Shoe
This link gives step-by-step instructions with pictures for replacing the shoe.
http://planetneil.com/tangents/2007/05/31/repairing-the-canon-580ex-hotshoe-foot/
Jun 16, 2008 | Canon SPEEDLITE 580EX TTL Flash
Broke foot of Canon Speedlite 420EX TTL Flash
Part # CY2-4165, order from Canon. Four screws and a plug in cable and that is it.
Mar 08, 2008 | Canon Speedlite 420EX TTL Flash
285 not 285HV
You can make your own or repair the shoe.
Use Weld Bond, buy from auto store.
Buy plastic, then cut & stack & Weld Bond.
atdlee@netzero.com
Dec 02, 2006 | Vivitar 285HV Flash
Vivitar 283 Flash Logo
638 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
