Question about Cameras
What is the best picture size setting to use for general use with a non SLR digital camera using the fine or super fine setting?
  • Anonymous Jan 17, 2009
    need to make picture file smaller
  • 10,594 Answers
Super Fine picture file size needs more space in memory card where as Fine picture file requires less. Its up to you, if you have big memory card, shoot pictures in S.Fine mode.
Generaly, Fine picture mode is being used to take more n more pictures.
Posted on May 30, 2008
What setting is best for taking pictures at night(?)
IR/ night vision, Black and white also seem to work good most of the time too. Just keep playing around until you find one that suites your needs. Happy refraction !!!!.
Apr 03, 2015 | Vivitar ViviCam 5385 Digital Camera
My Pentax K100 DSLR is flashing "av" and will not take a photograph, though the shutter works fine and takes pictures without the lens.
"AV" means apeture priority. This means that you set the apeture that the camera will use, and it decides the shutter speed. The flashing "av" means that you've picked an apeture that the camera can't pick a suitable shutter speed for at this light level. I would suggest picking a different apeture, or switch the camera to full automatic mode via the dial on the top left of the camera.
Mar 03, 2011 | Pentax K100D Super Digital SLR Camera
What size lens does this camera use?
Hello kry...With a large selection of lenses, the Konica Minolta 400SI offers a range from super wide fisheye to 600mm super telephoto. Joe
Thanks for choosing Fixya!
Feb 18, 2011 | Minolta Maxxum 400si 35mm SLR Camera
The canra says DCF full error agter taking 7 pictuturs
Hi. The PL80 has an 86MB internal memory so it does not sound as if there is anything wrong. However you can buy an SD or SDHC memory card and use that as well, so you can take a lot more pictures.
The number of pictures which can be stored depends on the size of the internal memory, or the extra memory card, and whether you set the camera to record the images in 'Normal', 'fine', or 'super fine' mode. This determines how compressed the images will be, and how much memory each one will use up.
A 1GB card would give around 160 pictures in super fine mode. Have fun with your camera!
Dec 27, 2010 | Samsung PL80 Digital Camera
How do you change the shutter speeds on an pentax k100 super, when it is on the AUTO PICT setting?
You can't.
In Auto Pict mode the camera selects the best of the pre-set Scene modes for the photograph which you're about to take. It's basically a variation of fully automatic mode, so the camera selects everything for you.
Auto Pict and Auto are designed to let anyone pick up your camera and take a fully automated snapshot without needing to worry about what settings to use.
To alter the shutter speeds you need to select an appropriate mode such as shutter priority or manual.
Jan 16, 2010 | Pentax K100D Super Digital SLR Camera
Low resolution pictures from my Casio Exlim EX-Z750
Depending on what you're photographing, you can sometimes put it on micro mode (the super zoom mode). Whether or not you can do this, you should definintly bump it into fine or best quality, the more memory the picture takes up the better.
Ideal camera for uses like this would be one around 10 megapixels, this is the most that you should need unless you plan on blowing the pictures up very much larger than 8x10.
Jul 12, 2009 | Casio Exilim EX-Z750 Digital Camera
Cameras compatible with Quantaray AF 70-300mm lens
Depending on how new your Minolta SLR film camera was, the lens may or may not work on a Minolta Digital SLR. In many cases, a lens with the correct mount (in this case, a Minolta mount) can be used on the same brand of camera in the digital format.
One thing you should know is that DSLR sensors are, generally speaking, smaller than the size of a 35mm film negative. Long story short, that means that your lens will have a magnification factor on the DSLR. Usually, it is in the range of 150%, so a 70-300 lens from a film camera would cover 105 to 450 on a Digital SLR.
To be sure about the mount, you'll need to seek advice specific to Minoltas -- probably best to take your lens to a local camera shop and see for sure if it fits and what features will work (aperature, auto-focus, etc) and which won't work on the DSLR.
May 31, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Hi could you answer a question for me about the pentax mv
The Pentax MV has a similar body and uses the same lenses as the Pentax ME Super, but it is a fully "Auto Exposure" camera. It does not have manual override or shutter-priority modes. It is a good camera to take pictures, but not if you want to have full manual / creative control over the camera.
Take care & Happy Imaging!
Glen
Jun 18, 2008 | Pentax ME Super 35mm SLR Camera
Night shots
Hi: Well, I think you have a problem because you cannot take still shots at night :) Not even with the best SLR. The camera as to get light to make the picture. My advices are, not only use the tripod but when you shoot, but set the timer function so you don't touch the camera when it shoot's and use a high time of exposure like 2 or 5 seconds depending on the subject... Make several experiences with low resolution and when you suceed, make it with a higher resolution ;) Regards
Sep 04, 2005 | Fuji FinePix S5500 Digital Camera
Settings
The best picture quality setting on the D-390 is SHQ (Super High Quality). The SHQ file is the largest of all four quality settings. The image file size is approximately 786K.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Cameras Logo
122 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
