Cyrus 2 amplifier 1 channel not working - Audio Players & Recorders
  • 3 Answers
My brother-in-law had the same problem with his Cyrus 2 and fixed it by removing the cover and blowing compressed air (carefully) to blow out the dust and muck on the inside.  That fixed the problem for him.  It has been almost a year since your question--I hope you still have it so you can try this fix.  It's a great amp worth the easy fix.
Posted on Apr 07, 2009
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Cyrus 3i amplifier play rumors
cyrus 3i internal photos please
Mar 03, 2010 | Audio Players & Recorders
My Peavey Mark 3 400 CHANNEL 1 does not put out sound. When you turn the pre gain it will cut in for a sec then out. Channel 2 is good. I checked the readings on the pre gain pot on channel 1 and 2 and...
Transfer Channel 2 speakers to Channel 1 to check if it does put out a sound. If it does, it means that your Channel 2 amplifier is defective. However, if it doesn't,
then your Channel 2 speaker is defective. So, have this checked to find out the result. Defective items needs replacement or be repaired. Send us your e-mail for the result so we can further extend our assistance.
Oct 13, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Ok . i have a pair of crossfire subwoofers, @
Your amplifier is 4 channel... and only 2 ohm stereo capable.
You will get the most power putting 1 subwoofer wired in parallel on each BRIDGED channel.
This will give you a 2 ohm stereo load.
Both + on 1 subwoofer to + terminal on amplifier bridged channel 1
Both - on 1 subwoofer to - terminal on amplifier bridged channel 1
Both + on 1 subwoofer to + terminal on amplifier bridged channel 2
Both - on 1 subwoofer to - terminal on amplifier bridged channel 2
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | DHD NTX-3102 Car Audio Amplifier
I cannot find the specs or user manual on the JVC archived items list. A few sites want to charge $10.00 for the user guide info, but I think that is too much to charge.
Defiantely not 200 watts
KS-A82
  • 2 Channel Amplifier
  • Bridgeable 2 channel amplifier
  • Output power: 25W x 2, 20 - 40,000 hz at .08 THD
  • 2 ohm stable
  • Adjustable gain (.1 - 2v)
  • MOS-FET DC-DC converter
  • Multi phase connection
  • 1 Pair of line input terminals
  • Remote relay turn on system
  • MSRP: $159.95
http://www.admtechusa.com/JVC.html#KS-A82
May 22, 2009 | Car Audio & Video
I have a rockford fosgate p250.2 amp hooked up to two 12' subs but the amp is not powering on... instead the protect light is on and im not sure if its because its so cold outside... please help and thank...
Remove the load from the amplifier (subs) and the RCAs
Retry.
If the light stays on, there are internal problems with the amplifier, and it needs to be serviced.
If the amplifier works normally, attach the RCA's and power on again.
If it remains on, connect one sub, and then the other.
Your amplifier is a 2 channel amplifier rated at
60 Watt - 4 Ohm - 2 channel(s)
125 Watt - 2 Ohm - 2 channel(s)
250 Watt - 4 Ohm - 1 channel(s)
Your amplifier is not rated for a 2 ohm mono load.
If you have Single voicecoil subs wired in parallel, you have a 2 ohm mono load - your amplifier will eventually fail.
Jan 16, 2009 | Rockford Fosgate Punch P2502 Car Audio...
I HAVE A 15' KICKER L7 2 OHM WITH A DIAMOND AUDIO 2 CHANNEL BUT AM ONLY USING 1. HOW DO I WIRE THE VOICE COILS
hi so you have to connect your minus point of your speaker to the positve channel 1 amplifier output, after you connect the positive channel 2 output amplifier to the first coil connection (no polarised) and the second coil connection to your positive point of your speaker, this solution if you can bridge your amplifier to one channel output.
if you can't bridge your amplifier, you have to connect your minus point of your speaker to the negative channel 1 amplifier output, after you connect the positive channel 1 output amplifier to the first coil connection (no polarised) and the second coil connection to your positive point of your speaker
I hope this helps
Please rate accordingly
Thank You
sserpentio
May 03, 2008 | Car Audio & Video
Bridged
setup of bridge mono mode:-1-turn your amplifier off.2-connect input wiring to channel(1) input--3-connect speaker across positive outputs terminals-do not use negative terminal when amplifier is operating in bridge mono mode.4-turn down (fully counter clockwise)of channel (2).
Mar 13, 2008 | Crown CE1000 2-Channel Amplifier
625 people viewed this question
 Grubhead
Grubhead
