Question about Sharp LC-37BX5M 37 in. LCD TV
We have a sharp aquos 37 inch flat screen tv (I think it is LC-37BX6M) Lost the owner's manual. We can't get volume, even though it appears to go up when using the remote or the button on the tv. We have already checked that the mute button is not on. Tried manually adjusting audio with TV settings also.
  • 1 more comment
  • puwelch Oct 09, 2010
    Tried unplugging tv for over 1 min. still no sound. also went to audio option settings - audio is on.. plugged in dvd player and played disc as well as wii. still no sound. what else?
    already tried that ! no sound comes out of tv
    not getting sound no matter what
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the audio with a DVD player or cable box. Also try using component cables if using a RCA component cable or vice versa. Check that all of the cables are plugged into the back of the TV & MUTE button is not pressed. Do a hard reset by unplugging the power cord for more than 4 hours and power it again, then go into the on-screen-menu and make sure the sap is off and stereo in on. Also try audio from Phone and 3.5mm jacks (if equipped). If this all didn't resolves the issue then it is an Audio IC or bad speakers/speaker connection. You can also download the manual from this link:
Sharp LC-37BX5M Manual
Please accept the solution if the issue is resolved else revert for further assistance.
Thanks
Rylee
Posted on Oct 09, 2010
  • 10,594 Answers
Unplug tv from wall socket for minute to get it reset, replug back in and turn On tv to check sound output.
If sound problem still not solved then check Sound Menu options and make sure TV Speaker option is On/Enable.
Also connect any receiver/ amplifier at TV Audio Out terminals at rear of tv to confirm sound processor in tv is working or not.
Let me know your findings.
Thanks.
  • Shahid Electronics
    Shahid Electronics Oct 09, 2010
    Connect audio wire from TV Audio Out pins to external amplifier input to get TV sound from amplifier's external speakers.
    This will confirm that sound processor in tv is working.
    If still you do not get sound then main board of tv will be replaced by professional to solve sound issue.
    Thanks
    Replace main board of tv as there is no other solution for that problem because sound processor and sound out put chips are mounted on main board.
Brand new TV, spotty HDMI functionality (sometimes recognizes cable box or comupter, but not always). Attempted firmware update on a Sharp Aquos LC-32SH7E (European model). Don't think it ever...
Did you go through the entire factory reset? When you plugged in the power cord did you continue to hold the volume - and input button until the television powered on and a K appeared on the screen never releasing at all?
Force the tv on by holding down channel down and volume + on the tv while plugging the tv in. See if the tv still lights up and if you get audio.
Jul 28, 2010 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
My sharp aquos has low volume
my sharp aquos flat screen has a low volume, even when turned up to max. how can i increase the volume
May 24, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I have a Sharp AQUOS LC-19SB14U 19' LCD TV that won't power on
The main power transistor in the power supply appears to have failed. It has also blown the fuse. Not a job for the DIY'er unless you have serious electronics experience.
Mar 08, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Have a sharp aquos TV. Cannot get the volume very
If you have the tv signal coming from the cable box, then check the settings for your cable box. if not check your owners manual.
Feb 08, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My sharp aquous tv has white lines running vertically like a pin-striped suit.
my 32 inch sharp Aquos has white lines running in the background of the screen
Jan 28, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
Oct 15, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp LC-37BX5M 37 in. LCD TV Logo
191 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
