Question about Konica Minolta Office Equipment & Supplies
C1183 error the trays desent and rise normaly put the stapeling unit coms at the front? this must be in center? thanks if anyone can help bart
  • 1 more comment
  • lippie1966 Oct 09, 2010
    Daniel,
    that i have try alredy
    but stays the same
    thanks bart
    Daniel,
    I have try that
    stil no change
    thanks bart
    somwhere a picture with the position of de sensors?
    thanks bart
  • 4,323 Answers
Hi
Error code C1183 means finishing option elevator drive malfunction. It appears due to tray lift motor failure on the finisher. To trouble shoot the issue turn off the power and open the elevator section to check the elevator motor. Wait for 2-3 minutes and check if the issue is resolved. If this doesn't work then check the alignment of front and rear rollers of the finisher. Also make sure that the finisher exit guide rollers are fine & the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. Sometimes this error may appear due to a broken lower gear by the pin slot. Hope this helps...
Daniel
Posted on Oct 09, 2010
  • 2 more comments
    the finischer lifts and comes in position
    but stil the same error
    maby a sensor somhere?
    a have try a hard reset
    still not working
    my copier is a bizhub c300
  • Daniel Scott
    Daniel Scott Oct 09, 2010
    Hi
    Try this reset procedure---
    Turn off the bizhub. Hold the utillity button down and then turn the main switch on. After the logo appears let go of the utility button and the trouble bar will appear. On the touch bar it will say ok. Turn the main switch off, and then turn back on after 20 seconds.
    Thanks
    Daniel
  • Daniel Scott
    Hi!
    Check the following sensors---
    C1183
    Elevator motor ascent/ descent drive failure
    • The elevator tray lower limit sensor (PC13) is not turned ON even after the set period of time has elapsed after the main power switch is set to ON.
    • The elevator tray home position sensor (PC11) and elevator top face detection sensor (PC12) are not turned ON even after the set period of time has elapsed after the elevator motor (M11) is energized.
    • The elevator tray does not stop at the position for the specified tray after the elevator motor (M11) is energized (beginning of descent operation) and the elevator tray lower limit sensor (PC13) is turned ON.
    • The elevator top face detection sensor (PC12) is not turned ON even after the set period of time has elapsed after the elevator motor (M11) is energized (beginning of ascent operation) when paper is being fed out.
    Check if the finisher is correct mounted also the bins should mounted correct with screws.
    Check if the black lever actuator moves free.
    C1183
    Thanks
    Daniel
SOLUCIONAR PROBLEMA DEL ERROR C1183
Did someone leave a trash can or boxes under the output trays? To solve this problem requires removal of the rear cover of the finisher. Then remove the elevation drive motor assemble. Be careful don't want the output trays to fall!!!!!! Then while placing them in their proper position re seat the drive assy. The top tray should be just below the orange rollers (If they are cleaned) you will see several actuators the top tray has to just touch them.
Mar 22, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 222 how to open elevator section
Check the exit sensor on the elevator tray (paper exit unit).
Jan 01, 2013 | Konica Minolta Bizhub 222 Black and White...
Hi please can you help me to resolve my problem with a bizhub 35 it's get me a code number c1183
Hi elfethi,
This code c1183 is commonly caused by trays in your finisher which are not fully inserted into it's slot. It indicates an elevator motor Ascent/Descent Failure. You may want to try follow these steps that help you address the concern:
1. Check the output bin trays which are at the far left side of your machine.
2. Make sure that they are properly installed into the holders.
3. Then refresh your system by turning it off and on.
4.After doing these, the error should be gone.
If you're still getting the error after making sure that trays are properly installed then this means that the issue is already with the sensors or elevator motor. You will need to contact a local repair man.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
C1183 error
C-1183 = Elevator Motor Ascent/Descent Drive Failure
This code means something is stopping the finisher exit trays from moving. Check your finisher exit trays. Make sure nothing is under them blocking the movement. Make sure they are level and have not been knocked out of place. Open and close the front door and reset the machine power and see if the trays move. They are suppose to move and find home position when resetting.
May 24, 2010 | Konica Minolta Bizhub 362 Copier
Its saying the code c1183
Oh wow, you have the talking version!!
Just kiddin' :-)
C-1183 relates to the finisher/sorter on the left hand side of the machine.
Something happend either when the tray was going up or going down.
The machine detected this abnormality.
It could have been a waste paper bin or something under it, or a heavy object placed on top.
Open and close the finisher. It's also worth blowing inside, up by the top cover of the finisher.
There's a sensor in there which can get dusty.
Hope the above helps
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 erro code c1183
C1183
May 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Xerox Phaser 8200 false "Replace Paper Tray" message
I've had a similar problem with a client's 8200 printer, and looking at the right hand side of the tray someone had previously put some tape over the topmost 'slot' (above where the green slider goes across).
I put some new tape over the top slot and the 'replace paper tray' message went away.
Admittedly, the tape gets pushed in so I don't know how long it will be before the tape gets dislodged and the error re-appears.
The printer is well out of warranty and they don't want to pay anything to get it fixed... so this solution is fine with them.
Hope this helps someone else out there :-)
Jul 02, 2008 | Xerox Phaser 8200 Laser Printer
Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
Malfunction Detected Error c-0211
C0211 Manual Tray Rise Descent Error
• The Bypass Lift-Up Sensor is not blocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the standby position to the feed position was started.
• The Bypass Lift-Up Sensor is not unblocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the feed position to the standby position was started.
This is a rank B error. To reset follow these steps:
Open and close the front door.
If error recurrs check the manual bypass again or call for service.
Dec 04, 2007 | Konica Minolta bizhub C250 All-In-One...
545 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
