Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Oil leak left side by head not valve cover runs down side of block on on frame of grasscutter runs fine
2 Suggested Answers
  • 4088 Answers
SOURCE: hello.oil is leaking from the hose that comes out of valve cover
Under the carburetor, there is a solenoid valve that is supposed to have + 12 volts across the two terminals when the ignition is on. It is designed to shut off the main jet in the carburetor when the key is off. The solenoid is prone to sticking and may be about half-way stuck in your case. Turn off the fuel valve under the tank. Remove the solenoid and observe the core action when the key is on-off. It may be cleanable, but probably better to replace it. Hope this helps!
Posted on Jun 07, 2010
Oil leak
check the oil filter mounting bracket at the block
Apr 16, 2014 | 2002 Audi A4
Leaking oil
Could be running down from the valve cover gaskets, bad or damaged head gasket, hole in oil pan, rear main seal, or oil filter housing
Nov 11, 2013 | 1997 Dodge Neon
2002 tahoe back of motor oil leak, already changed rear main
If you have oil running down the side of the block (from above the oil pan) check the lower edge of the valve cover. Those gaskets often fail to seal when the fasteners eventually work themselves loose
Check the fasteners that secure the valve cover to the heads. Torque to 3 ft lbs.
If the leak persists... replace the gasket.
Aug 10, 2017 | 2002 Chevrolet Tahoe
Oil leaking out of front of motor
Two very likely causes:
1) Leaking oil pressure sending unit.
This small round unit is screwed in to the block and has a wire or two attached to it.
2) Leaking valve cover gasket. Oil runs down the side of the block.
Be blessed.
Jan 23, 2013 | Cars & Trucks
2000 Mazda Protege 1.6L big oil leak passanger side. No oil in timing belt area. All over firewall & steering rack. What is leaking?
probably gaskets are not sealed properly you have to redo it or try and cleaned it remove all the oil that sorrounds the engine and try to seal with a high temp silicon
Jan 17, 2013 | Mazda 323 Cars & Trucks
Hi, I have a Suzuki Katana 1988 with a slight oil weep where the head gasket meets on the left hand side of cylinder head. I have re-torqued the head bolts and replaced the valve cover gasket. Riding the...
hi what you have just described is the head gasket leaking.you say you do not get a drip on the floor??check to see if the oil has travelled towards the rear of the head??if so how much??although this will not really affect the bike under normal riding it is recommended that you get it repaired sooner rather then later.
Mar 08, 2011 | 1990 Suzuki GSX 1100 FK (Katana)
Head Gasket?? Valve cover Gasket???
most likely it is the valve cover gasket. it covers the valve train where there is alot of oil to lube the top of the motor. if the head gasket was leaking it may have more signs of running poorly. also having coolant leaks also. so i will have to say valve cover gasket. now usally you may have a oil burning smell with it depending on the area of the lek but not always.
the valve cover can easily be seen when the hood is open. it is right on the top and where it meets the clyinder head is where the gasket is and the leak can be seen.
if you have more question please ask.
Nov 12, 2009 | 1997 Geo Tracker 2 Door
Have oil in my radiator fluid reservoir tank. Let a friend due a tune-up on car and i gave him a pcv valve to put on car he put it on the left valve cover in rear (if looking at car) in my book it shows...
someone has just reversed the valve covers swapped them from one to the other as far as the oil concern, sounds like you either have a leaking trans cooler in radiator or you have a blown head gasket
Mar 10, 2009 | 1993 Ford Mustang
1995 Suburban oil leak at # 7 exhaust port.
BAD valve seal or slight leak in head gasket if its not coming from valve cover gasket. Good luck and Thanks for using FIX YA
Feb 22, 2009 | 2003 Chevrolet Suburban 1500
Leaking oil bad
If you're certain it isn't your oil filter, then it can only be three other things. The first (and easiest) thing to check is a small diamond-shaped plate on the side of the block, under the intake manifold, towards the alternator. It has a bolt and a stud in it. Verify that both of those are tight. If they are tight, check the four bolts that secure the "push rod cover" to the side of the engine. The push rod cover runs the length of the engine and is located directly under the intake manifold. This was the culprit of my oil leak, and I imagine it will be yours also. However, if you find that those bolts are tight and no oil can be found leaking from that area, check your valve cover. The Fiero valve covers were stamped from very pliable steel and it is difficult, at best, to get them to seal correctly. Problems usually occur when people torque the bolts too tight and bend the valve cover. I recommend a product called "Indianhead" gasket shellac. Remove the valve cover and ensure all gasket surfaces are clean. Ensure the valve cover's gasket mating surface is straight - straighten with a hammer and block of wood if needed. Follow the directions on the bottle to the letter, making sure to coat your valve cover gasket surface, both sides of your gasket, and the gasket surface on the head.
Aug 02, 2008 | 1984 Pontiac Fiero
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
70 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
