Question about D-Link AirPlus DI-614+ Wireless Router
How do i get router connection to emule - D-Link AirPlus DI-614+ Wireless Router
2 Suggested Answers
  • 14 Answers
SOURCE: emule connection problem , DI- 614+ revB router
it sounds like to emule client is hogging all your bandwidth. Try and limiting your emule client to only use 70% of your total bandwidth. If you don't know your internet speed, then go to www.speedtest.com and run a test
Posted on Nov 18, 2007
Router DI-624
You should not require any drivers to be able to connect to this router.
If you want to configure the router you can simply connect to the router using a cable and if it is factory default you should be able to access it using your browser http://192.168.0.1
You can find the emulator at http://support.dlink.com/emulators/di624/h_wizard.html
Sep 02, 2012 | D-Link Computers & Internet
I keep losing internet connection since swapping to d-link wireless router, i am using channel 11
1. There is a emulator on the D-Link site that will walk you through the set up for your model router.
2. When looking up your router model on the site I saw that your model is discontinued but there is some "knowledge base" support for it but no further tech support.
Here is the D-link emulator link:
http://support.dlink.com/emulators/di615
follow the site prompts ( the site is interactive > that is it will respond to your clicking buttons or screen icons.
You probably will also need to check your Windows firewall settings.
Feb 07, 2011 | D-Link DIR-615 Wireless Router
Can conect wireless ,ethernet cable work fine but not wireless
.Log into router ( 192.168.0.1) enter into the browser window.
2. Verify wireless router name( on the computer) >>> ( on/off) on the status page in the router.
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Here is the instruction set for your model router :to set it up wireless follow the emulator instruction at this link:
http://support.dlink.com/emulators/wbr1310_revA/104/wizard.htm
This is for all routers to set up wirelessly.
Aug 11, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How to forward port to get high ID in emule
Here is how to set up port forwarding for emule: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule.htm If you use emule Plus see here: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule_Plus.htm
Jun 07, 2009 | Linksys WRT160N Wireless Router
Emule Show Low ID on Client Computer
Dear sir/madam,
You can update the servers it may be become fast. Go this site and add all servers (add to emule) click this link, they automatically update the servers.
http://ed2k.2x4u.de/index.html
OR try this
First of all you need to know the IP of the computer that you use with Emule.
Then go to the router configuration:
- Choose "NAT Settings", and "Virtual Server".
1- If it isn't enabled, enable the "Virtual Server".
2- In "Well-Known Applications" choose de option "User defined".
3- Now the crucial part. Under the Virtual Server List, in the "Local IP" you place the IP of your computer (on the example, 192.168.1.2, i.e. my emule computer ip), "Port Range" put 4662 and Protocol TCP. "Protocol nº." stays blank, and in the "description" you can put Emule Rule Nº1.
4- Click ADD, to add the rule to the table.
- Again you make the same passes from 3 to add the second rule:
3- In the "Port Range" you place 4672 instead 4662, and on Protocol you place UDP instead TCP. On "Description" you can place Emule Rule Nº2.
4- Click ADD.
5- After making the 2 rules, click Finish, and on the next screen click on Save&Restart button.
In the next time you start Emule, you can acess to the servers without Low ID.
Don't forget to rate the solution
thanks
Mar 23, 2008 | Computers & Internet
Emule connection problem , DI- 614+ revB router
Nov 18, 2007 | D-Link AirPlus DI-614+ Wireless Router
Low ID on emule when am using Belkin F5D7230-4 router
You need to find out what port Emule uses for sharing, then enter the port number in you routers Firewall Virtual Servers menu in the settings and enable your pc's ip address to accept inbound connections.
Jan 20, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Configure for emule
You must open ports on your router to allow incoming traffic while using eMule. eMule uses three ports*: 4662 (TCP) 4672 (UDP) 4711 (TCP) Visit eMule here. * To prevent getting a low ID (Firewalled), open additional TCP ports between 4661 and 4665. Also, limit the number of connections in the eMule software. You may need to change the TCP Clientport to something other than 4662.
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
D-Link AirPlus DI-614+ Wireless Router Logo
61 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
