I've damaged my Iomega REV drive while transporting it in a bag. The eject button no longer "clicks" and when a disc is inserted it will not come out again unless it's ejected manually (i.e. by inserting an unbent paper-clip into the little hole). Can I get this drive repaired and if so how or do I need to buy a new one? Many thanks.
  • MagikGimp May 31, 2008
    Wow, I wasn't expecting such a prompt response that was also very useful for a free service, I just thought I'd post this as a last resort; thank you very very much! I'll have to buy a suitable Torx screwdriver set as the screws are much smaller than any heads I have already. Hopefully this will save me the cost of a new drive, I am so surprised that I am not the only one who has had a problem like this.
    Many thanks again!
  • MagikGimp Aug 19, 2008
    It's taken a while but it's Fixya'd! For anyone else who might experience a similar problem I'll explain what I did in the hope that this is of some help to you:
    • What took me so long to get this done was acquiring a Torx 4 screwdriver to unscrew the screws holding together the REV Drive's case; in the end, after traipsing around too many hardware stores that only had 5s and larger, I had to order a set from Hong Kong. Once the case was off the tact switch actually fell out, the jolt the drive got in my bag must have knocked it so hard the solders broke.
    • To get at the switch's orignal resting place the REV's large, green circuit board also needs to be detached (all same screw size); once this is done unplug the tiny socket. You can work out where the switch goes as there are two holes in the board that line up with two extrusions on the back of the switch.
    • After stupidly trying to glue back the switch (the switch is close to other componants so I thought my clumsy hands might solder something else than the switch) with model-kit clue (don't even consider it, messy and just breaks off again) I did in the end manage to solder the switch back; just go slow and steady.
    • After that I tested the drive. Two things to mention here: you need to plug in the little socket and screw the circuit board back down otherwise the eject mechanism won't work but before that check that the little plastic eject switch is resting in the right place; check its orientation with the case and that it overlaps the mini-LED in front of the tact switch, you'll see what I mean.
    • After that screw everything else back together and Bob's ***********'s brother.
    NOTE: I can only presume that I also damaged my REV's eject button as to push it now is stiff and sticks to the case, because of friction, pushing the tact switch but not sliding back again. I can live with this as I just use the Eject command from the drive's right-click menu in Windows.
  • 4,234 Answers
There is a small tact switch behind the plastic button that may be damaged. This switch can be easily replaced by anyone experienced with electronics repair. They will need to match the switch in size with the one that is already there. Figure on the cost of the actual switch to be about $1-$2. If the switch is OK, the plastic covering may have gotten jammed inside the cabinet housing. Try dis-assembling the cabinet to see if the button can move freely.
Keep us posted.
Dan
Posted on May 30, 2008
How to remove a zip dik manually
Insert a paperclip into the hole in the manual eject button on the front of the drive... (fyi older drives have the hole in the back) Insert the paperclip and it will manually eject the drive
Jul 10, 2014 | Iomega Zip 100MB (31714) External ZIP...
SD CARD reader error: Insert removable disk into drive F:/
One of two I was say is the issue.
  • When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
  • You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Dec 18, 2012 | Electronics - Others
Iomega Rev Disc Write Error
you might have finalised the disc on the first burn or you have not selected to burn a multisession disk
hope tis helps
Jun 07, 2012 | Iomega (32961) External REV Drive
I have a mac and a new iogmega external drive, 500g. I cannot move any files onto the iomega or save them. I get messages such as "that file does not exist" to iomega can't be modified,...
With the drive plugged in, going into your Applications ' Utilities ' Disk Utility Select the drive and press Verify Disk, Repair Disk and Repair Permissions. If you don't have anything on the drive right now, try formatting it with the Mac OS Extended (Journaled) file system from the Disk Utility.
If that doesn't work the drive may be damaged. If you have another PC / Mac, trying plugging it in and see if it works there. If the drive is under 1 year old it should still be under warrantee, in which you could return it / RMA and get a new one sent back from the manufacture.
Regards, Chris
May 31, 2011 | Iomega (33090) 250 GB Hard Drive
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
My Iomega Rev drive keeps ejecting the disks I put into it. It has been backing up reliably for a few years now and recently it started ejecting every disk I put into it.
FWIW, I had the same problem...here's what I did.
I would insert a disk and it would get ejected immediately...didn't even look like the light in the eject button would flash. Rebooting the drive and computer didn't work.
I inserted a disk.
Before it could be ejected, I pulled the plug on the Rev Drive.
I waited several seconds
Re-plugged in the rev drive.
It seemed to read my disk and I was able to use my Rev drive. (So far so good...knock on my wooden head.)
Luck
- J
Jan 03, 2009 | Iomega REV ATAPI HDR B/U KIT CA 6 REV...
Cartridges will not stay in & cannot see the device in 2003 enterprise
Turns out the PSU unit was weak. It couldn't provide the power needed to spin up the disks when inserted.
Problem Solved.
Apr 06, 2008 | Iomega REV Tape Drive
Can't Insert the tape
If a white colored pin is broken in the drive it will eject. The pin engages the locking mechanism.
Sep 04, 2007 | Iomega (32961) External REV Drive
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
