Question about Technics SL-BD22 Turntable
Technics sl-ql 15 linear tracking T/Table
Missing arm screw that secures TP4 cartridge in arm. probably same as others in range as SL-5 one works fine.
the_wint@hotmail.com
  • 515 Answers
Parts are discontinued for these models. You need what's called a P-Mount cartridge screw. Try the following company:
www.lpgear.com
- DAVIS
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
Posted on Jul 12, 2008
Owners manual for SL-L3 turntable
Two Speed Direct Drive Fully Automatic Turntable with linear tracking ... Technics SL-L3 / SLL3 owners manual, service manuals and schematics are for ... www.vinylengine.com/library/technics/sl-l3.shtml
hope this will be of help
Feb 02, 2012 | Audio Players & Recorders
Hi! I've replaced my old stylus on a technics sl 20 (EPS 270 ED) by a tonar 757-DE elliptical, as it was recommended. The result is disappointing. The lows seem right, but the middle and higher range is...
You definitely want to make sure that your new cartridge is properly aligned for your turntable. This web site can help:
http://www.audiophilia.com/features/cartridge_setup.htm
If you don't feel that you are able to get it properly aligned by yourself, a local dealer should be able to help you with this for a small fee.
Mar 08, 2011 | Technics SL-BD20D Turntable
What replacement stylus cartridge do in need for my SL-QL 15 turntable?
You can fit whatever will fit on the headshell of the arm. It depends on how much you want pay otherwise for one.
Feb 04, 2011 | Technics SL-BD22 Turntable
TECHNICS SL 1910 TURNTABLE SERVICE
The grease and lube in the mechanism will
need cleaned out and replaced due to the
"age" of table! The "lifter" may be bound
up due to grease drying out...
Apr 17, 2010 | Technics SL-1210 Turntable
How to install shure m44-7 cartridge on technic sl 1200.ive aproblem with the wt.,as i feel the shure cartridge is lighter then other cartridges do ihave to install extra wt. with the cartridge
No, you should not need to install extra weights. Adjust the tomearm counterweight (on the back of the tonearm).
Install new cartridge.
Set tracking force dial to zero.
Adjust counter weight so tonearm floats vertically. This is the balance point.
Dial in tracking force, 1 to 3 grams.
If you cannot achieve balance point then you may have to add weight between the cartridge and the cartridge mount
Oct 20, 2009 | Technics SL-1210 Turntable
Suggested lubricant for Technic SL-5 linear tracking tonearm
technics used special grease for lots of their products, any good quality grease will do but use sparingly
Apr 07, 2009 | Audio Players & Recorders
Technics SL-5 Turntable will not turn.
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
Tone arm skipping/not moving on especially at end of record
The issue is with your tonearm, and not your tracking. You probably have slight damage to the tonearm bearings, which will cause this. There are 2 options... you can try to adjust the pivoting screw at the top of the tonearm ... However, WE DO NOT RECOMMEND THIS, because once you mess with this screw, it's EXTREMELY difficult to get it back to the correct setting, as this screw is machine calibrated at the factory. So, we only recommend this when you have no other choice, or it's an emergency (the middle of a set).
You can view a video on how to do this, by going here - http://djprolab.com
Eventually, your going to have to have your Technics Tonearm replaced. This should be done by a professional, as it is not an easy replacement.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 11, 2008 | Technics SL-1210MK5 Turntable
Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Oct 09, 2008 | Technics SL-1210 Turntable
Technics SL-BD22 Turntable Logo
696 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
