Question about Sony KP-57WS500 57" Rear Projection Television
Screen turns green and small red light on front flashes 8 times
    Genius:
  • 1,030 Answers
To me this is pointing towrd a bad (possibly shorted)green crt tube. howerver other possiblilities could be bad hig voltage distribution block(g2) 8 flashing means high voltage error. or an error on the d cuircit board error
Posted on Oct 09, 2010
How do I check the led light strips on my led lcd tv, to see if they work? and/or how do I replace the led light strips?
Contact any service technician. It will be best in this case. If you're sound in electronics, and have some previous knowledge in servicing LCD TVs; please respond. Otherwise please !!!!!!!!. Time is precious for us.
Jan 18, 2015 | RCA Televison & Video
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    May 04, 2012 | 1994 Nissan Maxima
    How do fix my 5 inch sony the light flashes 8 times
    Prior to this were you getting a bright red, green, or blue screen with trace lines?
    Apr 03, 2012 | Sony KP-57WS500 57" Rear Projection...
    The Screen Turns Green then shuts itself off? Is this the Bulb or something else?
    My sony 65Ws500 model about 4 months ago it started turning the screen all blue as soon as I turned it on. it stayed blue for about an hour then come back on normal now when I turn it on it will shut down and I get a small red light flashing 8 time then pauses and does it again 8 time then pauses then again and so on. I took back panel off. I turn on tv The blue bulb gets very bright and the green and red projection bulb goes out and now it shuts off. and the blinking starts it a code flashing but don't know the code to find out whats wrong. would someone help if u can been wife and I laid off from work 3 months now cant afford tech prices on our employment. wife and I has 2 little girls to raise. along with the rest of u parent out there and one getting employment cant offord repairs. Thank U. Adams01220@yahoo.com
    Feb 13, 2011 | Sony KP-65WS500 65" Rear Projection...
    Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
    This is a set with bad picture tubes-not available except on rebuild basis.
    Are you seeing bright green screen and then set shuts off?
    Let me know so I can help--8 blinks is AKB error.
    SD TECH
    Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
    Sony TV Model No. KP51WS500 flashes green & turns off
    yes u will have to get a expert in but here is a guide to help your tv is going into protect mode if the screen is flashing green with white lines in it its likely that the green tube is faulty this is very expensive & u my want to purchase something else.
    Apr 08, 2010 | Sony KP-51WS500 51" Rear Projection...
    Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
    thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
    Apr 22, 2009 | Televison & Video
    Green flashes then tv turns off
    or a new lamp. you could first replace the lamp.
    the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
    Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
    Sony KP-57WS500 57" Rear Projection Television Logo
    272 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
