Question about Acer Computers & Internet
Floppy Installation Problem
I'm trying to add a floppy driver to my Acer system. The data cable wont fit the pin configuration on the drive controller interface. Pin 3 on the controller is missing, but on the cable it's pin 5.
I though all data cables were standard. Do I have to buy a different cable?
    Brigadier General:
  • 6,966 Answers
I think the cable is the other way around. The end which has a twisted portion and with or without pin 3 covered goes to the FDD while the other end with or without pin 5 covered goes to the motherboard. Pls refer to the image below.Floppy Installation Problem - 5303f10.jpg
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 30, 2008
How do i install a 5-1/4 floppy drive into a gateway e-3600?
The cable twist designates the master drive. Make sure the cable is the correct way round and you have power for the motors etc.
Mar 28, 2017 | Gateway Computers & Internet
I have intel d946gzis motherboard. i wan connect floppy drive on it . how can i do that ?
Simple. But I'm going to assume you know a decent bit about computers first and then try to spell it out simply afterwards.
Ok. The simple technical answer is that right next to your 24-pin power connector you should have a big white slot with lots of pins in it. This is for ATA drives. Next to it you should have a smaller black slot with pins in it. It looks almost Identical, but it's smaller. That's for your floppy. Mount your floppy drive in the case with screws. Hook up the power connector to the floppy drive, and then run the data cable from the smaller black slot to the corresponding slot on your floppy drive. Boot up and you should be good. Windows should be able to install drivers for it from its database of legacy drivers. Just to be sure, if I got the connectors mixed up then don't try to force the cable. It's been years since I've installed an ATA HDD or a Floppy. Put it in the one that fits. That's the good thing about computers: USUALLY It only fits in one place. If it doesn't then it most likely doesn't matter which one you choose.
Simple Version (attempt?):
Okay, let's see if I can do this without too much jargon. Open your case from one side or the other (usually the left side when facing the front of the case). Unplug the power from the back, and place your non-working hand on the metal chassis (frame) to ground yourself. If you don't understand why this is important, in lay-mens terms it keeps any static discharge from ruining the components inside the case. Now. set it on your lap with the unopened side of the case down. You should be looking at a lot of stuff, but mainly at the bottom there should be a big square... thing with a lot of wires and chips and connectors everywhere. Look towards the very very very very very left of this past all the chips and connectors. Then look down towards the vertical middle. You'll see two boxes, one white, one black, with a lot of copper pins sticking up. You should have a ribbon cable for your floppy drive. It's a big wide cable that looks like... well... a ribbon. One end should fit into the back of your floppy drive and the other should fit into one of the aforementioned boxes. There should also be, towards the back of the case, a big grey box that has a fan. It's where you plug your power cable in. It's your PSU (Power Supply Unit). It should have a lot of wires running from it going to all sorts of places all over the case. One of these should fit into another slot on the back of your floppy drive. Hook it up too to ensure that your floppy drive has power. Set the computer back down. I would leave the case off until you know for sure you're done. Plug it back in. Boot into windows. Wait a second after your desktop loads and windows should give you a notification telling you that the device was properly installed. Pop in a floppy to test it out and if everything works as it should you're good to go.
Dec 02, 2011 | Intel D946GZIS Motherboard
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Computer does not detect a Alps Electric Co. Floppy drive
check the data cable and power cable,does the light in the floppy stay on if so you have the power cable backwards.is the drive connected ot the right end on the data cable. if the answer to these are yes then you have a bad drive.
May 23, 2009 | Alps DF354H (DF354H168) Internal Floppy...
My hard disk cant be recognize when i install xp cd to my Acer M1641 with a vista OS. my cable is sata not IDE. how can i convert my vista to XP
You will need to install the SATA drivers for XP. First, download the proper drivers for your SATA controller and put them on a floppy (will properly have to use an external floppy drive). At the beginning of the XP installation you will need to press F6 and install your drivers.
Be aware that there are only a few external floppy devices that XP will recognize. (Sony, IBM are two of them).
Mar 24, 2009 | Acer Aspire M1641-U1521A PC Desktop
Broken Motherboard Pins
Can you try to just use floppy driver B socket or is their not one? Do you really need a floppy driver many computers now days do not have one using the CD/DVD burner for saving data. I have never heard of the pins being replaced, but nothing is impossible to fix.
Feb 23, 2009 | Gateway DX310X PC Desktop
Installation of BT-146
Yes, you need to plug in a 4 pin FLoppy Molex connector. Your power supply should have at least one. The power connector is right next to the Floppy Drive connector.
Also, the Floppy connector goes in with pin 1 (The red stripe) to the left looking at the unit from the back (furthest away from power).
There is no manual to speak of.
Jan 09, 2009 | BYTECC (BT144) External Floppy Drive
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Cannot install Windows XP Professional on Acer Aspire 4720Z Laptop
yu need to go to the the bios before you start the installation and change the Sata hard disk mode to IDE.then it will detect the hard disk.
May 05, 2008 | Acer Aspire 5610-4648 Notebook
Floopy disk
Hi
Regarding configuring flopy drive for desktop please check these things
The wire on the ribbon cable with the red stripe is the pin 1 end and there should be a mark on the floppy drive as well marking the pin 1 end. Sometimes a little arrow or triangle point at pin1 sometimes stenciled with a number.
Regards
Balisonu79
Feb 14, 2008 | HP External floppy disk drive cable...
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
