Question about Garden
Hello i need some advise on my wheelhorse mower model c120 12hp it was starting on the key but now it is sending power to the solanoide but is no longer engaging the starter motor. any ideas on what maybe the cause ? many thanks
I assume you have a Kohler engine and a standard original Wheel Horse wiring.It sounds as though either your solenoid is defective, or the solenoid has a bad earth. If you have current arriving at the positive side of the solenoid from the key when in cranking position and you're sure the solenoid is grounding properly then it's the solenoid itself. As a check you could flash the solenoid and your motor should crank: MAKE SURE THE MOWER IS IN NEUTRAL AND BLADES DISENGAGED. This will prove that the starter motor is good. It's then a matter of replacing the solenoid...a straightforward bolt job, please disconnect the battery as a grounding flash when refitting the solenoid could cause generator failure.
Posted on Oct 09, 2010
Wheelhorse
Hello Jill,
Can you post the make, model and serial number? They are usually under the seat on a tag. If you can find this info I should be able to help.
Oct 09, 2013 | Garden
Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
May 02, 2012 | Echo Garden
Lawn mower starts but then quickly stops again. Fuel and oil OK. Choke appears to be working as does fuel tap.
needle valve or float solanoid may be sticking. also check power to float solnoid, grey wire should have power and the black is ground
Apr 25, 2011 | Garden
I was wondering if this mower has a fuse.It was running fine and just died.Now when I crank it nothing happens.The last time this happend I jumped it off and it started right up.Now it's not even...
it has a blade fuse by the starter solanoid. here are other places to check.loose wire at solanoid,check safety swiches.they will have power in both wires from switches
Apr 24, 2011 | Garden
I need a owners manual for a Toro Wheelhorse tractor model 16-44 HXL
simple go to outdoorpowerequipment.com and enter make and model and you can download or print it in pdf form
Aug 27, 2009 | Garden
I HAVE A 1999 WHEELHORSE 312 IT WILL NOT START WITHOUT JUMPERING THE STARTING SOLENOID I HAVE REPLACED THE STARTER SWITCH AND SOLENOID AND CHECKED THE RELAYS AND SAFETY SWITCHES
check whatever engages your mower blades. If it has a lever that you lift into place to engage blades try wiggling it while turning the key
Aug 02, 2009 | Toro Lawn Mower With Toro Power Tools
Need wiring diagram due to toro wheelhorse 212-5 12hp not startin
Go to www.toro.com then customer care, then manuals & parts, type in model no. and see if you can find wiring diagram in the manuals.
Mar 30, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
300 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
