Question about HP Compaq MP1800 Multimedia Projector
My device is a MP1800 from Compaq, and i need to replace the ballast or the complet power sourece, where can i find it?
I own a HP MP1900 projector and it wont turn on anymore...the bulb does not look blown and it never gave a going bad msg?
First check that the plug is in the socket and the power is switched on. (don't laugh, a friend did that just last week!) Next check if the fuse in the plug is OK. If you have no spare fuse try swapping one from another plug that you know does work. Next check the projector for signs of an inbuilt secondary fuse. These are often a circular access about 1to 1.5 cm across that screws out of the body of the projector. Hopefully one of these may cure your problem.
Oct 01, 2010 | HP Compaq MP1800 Multimedia Projector
Does not power up. LED light near plug on on &
trouble shoot it first before we say that it is power supply, disconnect and connect it to ac sourece, press the power button, if no effect, it is power supply, but if the fans work, replace or check the vga cale to monitor, or the monitor itself
Jul 22, 2010 | HP Pavilion m7100y (PX189AV) PC Desktop
I have an Compaq MP1400 projector not working
Hello :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp or moved it out . They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way? That could cause overheating problem and what you see with your projector is one of it's symptoms .
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage .After cleaning the filter always remember to reset your projector .
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE RATE !
Apr 12, 2010 | Compaq MP1400 and MP1800 Replacement...
Driver download for Compaq MP 1800 Projector
Compaq has merged with hp now..you can find anything you need about your projector here http://h10025.www1.hp.com/ewfrf/wc/product?product=214124&lc=en&cc=us&dlc=en&lang=en&cc=us
Dec 15, 2009 | HP Compaq MP1800 Multimedia Projector
Do you know where i can purchase a power cable and manual for this projector?
You can download/print the manual by following the link below. I can't tell from the pics what type power cable the unit uses, but you can likely purchase one by contacting COMPAQ customer service through the web site www.hp.com. Hope this helps.
http://h10032.www1.hp.com/ctg/Manual/c01150567.pdf
Dec 07, 2009 | HP Compaq MP1800 Multimedia Projector
Problems with the power on a sony hdtv KDF42E2000
Maybe the probles is with the ballast. the ballast # is A-1247-118-A, no longer available, the replace ballast # is A-1247-19A, is the same.
May 19, 2009 | Sony KDF42E2000 42" HDTV
Compaq mp 1800
Most likely a bad cable. Try bending a little bit of the wire at a time and see if the color flickers back to normal, or you could just by another cable and see if that fixes it. Happens to a lot of the projectors I support.
Jul 31, 2008 | HP Compaq MP1800 Multimedia Projector
Compaq MP 2800
Hi there
Does your Projector support Windows Vista ?
Mar 07, 2008 | Compaq 207685-001 - Microportable...
HP Compaq MP1800 Multimedia Projector Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
