Question about Kenmore Sewing Machines
Stitching is too tight on top but loopy underneath
  • dmkparalegal Oct 09, 2010
    I have a kenmore, which tension button is for top and which for bottom. Does the stitch width matter?
  • 11,800 Answers
The tension in the wires is badly adjusted - too high on the upper bobbin and too low on the bottom one. How you adjust the tension depends entirely on the model of your machine, but it;s usually about adjusting a button or a screw.
Remember, you must redo the adjustment every time you change the type of the material you're sewing.
Posted on Oct 09, 2010
  • Azrael SRL Oct 09, 2010
    There are hundreds of models, from ones in which everything is manual, to the ones in which everything is automatic. The exact procedure for your exact model is in the user manual that came with the machine.
    No, the stitch width doesn't matter much, it's the thickness and strength of the material that has the biggest influence.
My stiches are loose on the bottom of my banner - is it the bobbin or a tension issue?
If the threads on the back are loopy, you need to tighten the top tension. If you have a spare piece you may want to run some of the plastic through the machine until you get the tension correct. If the top tension is too loose, the stitching will just pull out.
Jul 16, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Why is the bobbin side of stitching is all loopy
loops on the bottom means top thread isn't getting tension. Re-thread top thread with presser foot UP. Then test your seam again. If you still have loops, tighten the UPPER tension.
Nov 11, 2012 | New Home HF-106
I can't freely remove my work from the bed after sewing.
I know this sounds wrong, but I am very sure you are not threading it correctly. If the sewing is loopy on the underneath, it is not properly threaded on the top of the machine or not properly caught into the tension discs at the front/on the top. If the stitching is loopy on the totop, then the problem is underneath in the bobbin area. Sort of back the front-upside down.If you are sure you have threaded it correctly, then-1) Put the foot down to sew 2) turn the balance wheel to place the needle into the fabric 3) hold the threads to the back or side 4) start sewing. Because you are holding the threads, this stops them from being able to get caught up underneath. It will still happen if the machine is incorrectly threaded. If all this fails, what area do you live in??? Good luck, sewing is wonderful :)
Aug 06, 2012 | Brother Sewing Machines
Loopy stitching
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Mar 11, 2012 | Toyota Sewing Machines
My machine is a Singer Inspiration 4210. My stitch on top looks fine at first glance but it is birdnesting underneath. What should I do to correct this?
Check your top tension. It sounds like it may be too loose or the bobbin tension may be way too tight. Most likely it is the top tension that is incorrect though. The TOP tension effects the bottom side of the stitch and the bottom tension effects the top. If the top tension isn't tight enough it won't draw the thread up through the top side taunt enough and the excess underneath makes a big loopy mess.
Jul 29, 2011 | Singer Inspiration 4210 Mechanical Sewing...
I cannot get the tension right on my 2600 Brother machine. I am stitching in the ditch with three layers of material. Can you please help?
Make sure you have the right size needle...not to small. Then do a simple seam through three layers (doesn't need to be a seam just sewing through 3 layers of scrap) using a wide zig zag stitch. Examine the stitch looking at both sides. Do they look even, identical?
Think in opposites, ie the bottom thread tension affects the stitch on the top side and the thread tension on top affects the stitch on the bottom side. If one side is loopy then the opposite side tension is too loose (or, sometimes that side's tension is too tight). Adjust until both sides are identical looking. Then try stitching in the ditch like you wanted to.
Mar 30, 2011 | Brother XL-2600
The tension seems to be loopy on the underneath of the fabric just can't get it right
Tighten the top tension. To check the bobbin tension take the bobbin out and dangle it by the thread like you would hold a yo yo. A gentle flick of the wrist should cause the bobbin to drop down some but not just spin out to the floor, ie there should be some tension. If it hits the floor it is too loose. But if it doesn't release, fall, some it is too tight.
When you stitch a broad zig zag if the tension is correct it will look identical on the top as it does on the bottom. If it is smaller on the top then the bobbin is too tight. If it is smaller on the bottom than the top tension is too tight etc.
Mar 26, 2011 | Sewing Machines
The bobbin thread is loopy on the under side of the fabric. I tried adjusting the tension setting but it didn't help at all.
Loops stitches on the underside is typically from the TOP tension being too loose, however it can also be the bobbin tension is too tight, or a problem with the needle. I would check them in that order.
Hold the bobbin thread and let the bobbin dangle. A slight shake of your hand should allow the bobbin to move downward (lets more thread out) but not so much that it just drops to the floor. When you put it in again and try sewing look at the top stitches. Do they look overly tight? THen the bobbin tension is too tight. The stitching should look the same top and bottom with no loops.
If both tensions seem to be alright check to see if the needle is: 1. the right size and type of the fabric 2. not bent
That should fix your problem :)
Jan 22, 2011 | Husqvarna Rose
Tension problem
Set the top tension as recommended by the mfg - this is usually between 3 - 6.
Now re-thread the machine with the presser foot up and see if this doesn't eliminated the loopy stitches.
What appears to be an issue with the bobbin may actually be the top thread was not seated into the tension during threading and the tension cannot control the flow of thread to the needle and you get a loopy stitch.
Keep the bobbin case clean as built-up lint can cause stitching problems.
Feb 20, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
