Question about Clarion NX500 Car Video Player
I have a Clarion NX-500 and we're having problems with the clock. First, it kept jumping to an entirely different time (1/2 hour ahead). The guy who installed it disabled the "synching" between the clock and the navigator clock and it seemed fine.....now the time stays ok....but it keeps jumping to A.M. I set it back to P.M......then in a couple of minutes...it jumps back to A.M. Any ideas?
Http://www.teamclarion.com/Sharedwebdbs/clarionsupport.nsf/ce17209d69d0c0b688256ea0005a1fbc/70a5e00878ca4cb0882577eb005afb17?OpenDocument . follow the directions on the english pdf and it should update to the right firmware. make sure you follow directions exactly or take it to a clarion dealer to do it.
Posted on Feb 24, 2011
JVC KW-R920BTS. Clock is set to correct time. When connected to BlueTooth, clock jumps ahead one hour.
So the device connected via Bluetooth is advising the unit of the time because the device is calling the shots. One device is set for local time and the other is summer time. Change the setting on the Bluetooth phone or whatever to local.
Non one else has encountered this problem according to my search.
JVC KW R920BTS jumps ahead one hour when connected to bluetooth device...
Nov 28, 2016 | JVC Car Audio & Video
How do you set and turn clock display on naxa nx667
Naxa Electronics NX-667 Clock setting - Questions - Fixya
www.fixya.com > ... > Naxa Electronics > Naxa Electronics NX-667
Naxa Electronics NX-667, clock setting related issues. ... set up the clock time 1: press Source button to turn off unit 2: press Clock button to display clock 3: press ...
Naxa Electronics NX-667 Kd s35 manual - Questions - Fixya
...kd-s35 Press and hold SEL button. Press ^ button 3 times to display H (hour) turnvolume knob to change hour setting, press down 1 time to select M (minute) ...
General FAQs - Naxa.com
Dec 12, 2015 | Car Audio & Video
How to set clock on DXZ445 Clarion
Setting the clock 1. Press and hold the [T] button for 1 second or longer to switch to the adjustment selection display. 2. Press the [ '<< ] or [ >>' ] button to select "CLOCK". 3. Press the [ >'' ] button. 4. Press the [ '<< ] or [ >>' ] button to select hour or the minute. 5. Turn the [ROTARY] knob clockwise or counterclockwise to set the correct time. ∗ The clock is displayed in 12-hour format. 6. Press the [ >'' ] button to store the time into memory. 7. Press the [T] button to return to the previous mode.
Note: • You cannot set the clock when it is displayed with only the ignition on. If you drain or remove the car's battery or take out this unit, the clock is reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
Nov 09, 2010 | Clarion Car Audio & Video
How to set clock on clarion drx7375
Setting the clock
1. Press and hold ADJ button 4 for 1 second or
display.
2. Press the right or left side of SEARCH button
% to select “CLOCK”.
3. Press ENT button 2.
4. Press the right or left side of SEARCH button
% to select the hour or the minute.
5. Turn the Rotary knob & clockwise or
* The clock is displayed in 12-hour format.
6. Press ENT button 2 to store the time into memory.
7. Press ADJ button 4 to return to the previous mode.
Note:
only the ignition on. If you drain or remove the car’s
Sep 13, 2010 | Clarion DRX7575z CD Player
My clock jumps an hour ahead, how do I fix it?
Make sure that you have the clock set for the correct time zone, and that the DST feature is switched ON. If those settings are correct, try replacing the batteries. Weak batteries frequently cause an atomic clock to "jump" one hour in either direction.
I hope this helps.
Bill B
Aug 04, 2010 | Honeywell RC182WR Atomic Alarm Clock - Red
Two clocks are set at 6am one clock gains 30 seconds every hour and the second clock loses 1 minute every hour. at what time will the faster clock be 30 minutes ahead of the second clock
Compute the difference in clock-speeds, namely 90 seconds per hour.
Convert the units of time: 30 minutes becomes 180 seconds.
So, divide 180 by 90 to get '2', namely 2 hours after the 6 o'clock "start" time, which makes it 8 PM.
P.S. There is at least one error in the above solution. If you truly understand the solution, make the necessary correction, and submit the corrected "homework" to your teacher.
Jan 07, 2010 | M2K Garfield: It's All About Math Math...
Clock jumping forward 3 hours
Ouch, sounds like it's TIME for a new clock
Mar 12, 2009 | Philips MCD708 System
How to set the clock on the car stereo (Naxa nx-670)
I had the same issue. I bought my 671 mp3 car stereo from jujudeals.com and I was having the same problem. I called them up and they said that I have to go to clock mode. When in 'Clock Mode' you have to press and hold Select (SEL) and at the same time press FF/REV to adjust time. (Fast Forward adjusts hour, Rewind adjusts minute). If your still having problems contact the Naxa Electronics warranty department. Goodluck!
Jan 17, 2009 | Naxa Electronics NX-671 Car CD/ MP3 Player
Setting clock
1.Press and hold the (BND) button, then press the (DISP) button to display the clock display.
2.Press and hold the (BND) button, then press the (DISP) button for about 2 seconds (the number will flash).
3.Press the << button to toggle between hour and minute selections. Then turn the ROTARY(volume) knob to increase hour/minutes.
4.Press the (BND) button, then the clock is set!
Kurz
Apr 07, 2008 | Clarion DB245 CD Player
Clarion NX500 Car Video Player Logo
884 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
