Question about Goldstar MV-1501 Microwave Oven
No display is there a fuse inside
    Scholar:
  • 93 Answers
Fuse is a protective device.Yes, there is a fuse
Posted on Jul 24, 2008
How do I determine if the fuse is bad on a Frigidare #FMT118EPB Microwave? Thanks.
Michael, if the fuse is bad, it will take out everything on the microwave. You will not have any lights inside or on your display. You can find the fuse inside of the cover by following where your power cord goes into the unit and following usually the black wire to the fuse. Hope this helps!
Dec 04, 2014 | Frigidaire FMT118EPB Microwave Oven
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
Oct 21, 2017 | Jenn-Air JMV9169BAS Convection Microwave...
665.68601890 Acts as though it is not receiving power but breaker is not thrown. Is there an internal reset. Nothing responds - no lights, fan or microwave. Panel is black and non responsive
ther is on most microwaves a fuse inside usually located behind display panel located in a fuse block or will be on the control board itself.. normally a 20 amp fuse...try that first if not then make sure you have power to control and if so and no display most likely the display control board...
may luck out and be just the fuse though....good luck
Jan 08, 2011 | Kenmore Microwave Ovens
RCA Model RMW700 micorwave 1 yr old stopped working. No power, yet the outlet is live. No power to the display, no light inside, just dead. Stopped working when heating cold cup of coffee.
There is a fuse inside the cover of the microwave. You will need to remove the outer shell and follow the power cord you will see an inline fuse. This fuse can be purchased at any appliance parts house.
Hope this helped
Dave
Jan 19, 2010 | RCA Microwave Ovens
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
Microwave was ran for 5 minutes with nothin in it now no display
most have an internal fuse check it first if that is not it check the thermal fuse both parts run 10-15 dollars
Jun 30, 2009 | Maytag MMV4205 Microwave Oven
No display will not operate no fan no light
Ok, there is an in-line fuse that is located inside the unit on the power supply board. if this fuse is damaged, replace it. If this fuse is ok, replace the entire power supply board.
Jun 01, 2009 | Whirlpool GH4155XP Microwave Oven
Sharp R-930AK convection/microwave suddenly died
You need to open the oven (unplugged) by removing the screws along the case. Inside, there is a 20 amp fast blow fuse that you can get at Radio Shack. It looks cylindrical and white. I would test that first. However, replacing the fuse may work, but then, other components may have shorted inside causing the fuse to blow. Try the fuse replacement/test it first. Good luck
Apr 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Sharp Carosel R-1481 (no B) & 950 Watts
All MW has a fuse inside to protect the circuit board
Try to replace the fuse
May 10, 2008 | Sharp R-1481B Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
47 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
