WHEN (AKAI TV CT-CH2519E) TURNED ON,ONLY BLUE SCREEN WITH YELLOW RECTANGLE IN THE CENTER CONTAINING MANY +&-WITH FLASHING ONEAPPEAR .NO PICTURES OR MENU COULD BE OBTAINED
Danmart
  • 291 Answers
SOURCE: Akai TV Stuck in Video Menu Page
Unplug TV for about 2(two) hours, while the TV is unpluged press the on\off button on the TV every once in a while. Replug electricity and try to turn the TV without the r\c, use the on\off button only...If that does not work...u need a tech to look inside..
Posted on May 01, 2008
  • 8 Answers
SOURCE: Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
Posted on May 22, 2009
  • 5 Answers
SOURCE: Tv getting yellow/green tint cleaned opti box now no picture
chrome i.c change
Posted on Jun 08, 2009
  • 304 Answers
SOURCE: AKAI 27 Model #LCT2785TA
The message you are seeing means that the tv is not receiving a signal from the source. Try hooking up a different source such as a DVD player or a Cable Box to that same input on the tv. If you have picture and sound then the problem is with the original source. If that does not work then you have a bad Main bd.
Posted on Jul 16, 2009
SOURCE: spectroniq tv flat screen will not turn on, ablue light flashing
HMDI stopped working?!
Posted on Aug 24, 2009
How do I get rid of blue lines on tv screen on an akai bn59-00347
What blue lines? Do you want the blue electron gun turned completely off?
Apr 21, 2017 | Akai Televison & Video
Akai 52" rear projection...colors are off and screen is washed yellow
Sounds like the blue gun has died. I would say that you should call Salvation Army and have them collect it for you and buy a new LED flat screen TV to replace it.
Aug 02, 2012 | Akai Televison & Video
Have a akai tv that's has a green or yellow tint
Hello
Check the picture tube base card for any loose solderings. Your TV lacks Blue colour putput. Check all the solder points on this board. Resolder all the susepected solder terminals [especially take care to blue output section], by applying a little more solder. Check the base connection solder terminals of the blue output transistor. It might be loose, or transistor is defective.
Mar 29, 2012 | Akai Televison & Video
Akai tv 29 inch model ct 2979 circuit diagram i want this circuit can u arrange for trouble shooting contact ashokan7@aol.in
I want to get new circuit board for my old akai tv model ct 2979 a 29 inch screen tv whose EST has gone as per mechanic.Kindly tell me where to get & what is the cost? reply to drramesh2000@yahoo.com or call 09676217007
Feb 19, 2011 | Televison & Video
Akai ct-2202 tv turns on but no picture when i connect cable tv wire, cable oprator said me your akai tv tuner problum Please solve my problum Sanjeev Kumar Delhi, India
sir . i need akai ct2202 remote control model no. i lost my remote in transit and without it i'm not able to use the tv. my mail id : srikum74@gmail.com pls help. thanks & regard's. V.SRIKUMAR
Aug 04, 2010 | Akai LCT3285TA 32 in. LCD Television
AKAI LCT2016 20" LCD TV- Dosn't Resize picture properly
U can't fix this problems.Omly replaced board.The Tuner main board have dead componnents.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner signal board for replacement.
Feb 20, 2010 | Akai LCT2016 20 in. LCD Television
Child lock
my AKAI tv is locked. All i see is a blus screen with a little red lock on the bottom left corner! the only button that works on the tv OR remote is the power button on the remote. PLEASE HELP i have tried pushing every button but nothing happens
Feb 15, 2008 | Akai CTS2550 25" TV
Picture is suddenly "bowed" and the convergence is askewed at everypoint but center.
the problem is the EW cicuit of the deflection cicuit. this is a component level repair call a tech. the EW or East West correction is apart of the horizontal deflection. IC431 is the pin amp.
Feb 06, 2008 | Akai PT5598HD 55" Rear Projection...
Faded and out of focus picture
Your TV has a burnt CRT base socket. Replace that, it is not a tough job, but make sure that you get the exact same type of base socket.
Jan 14, 2008 | Panasonic CT-34WX15 34" TV
AKAI TELEVISION
Probable bad tuner or tuner circuit issue, repair or bypass.....
If you can direct signal to A / V inputs as you are doing with your
DVD, then no repair is necessary.....utilyze cable box or VCR
tuner to change channels.......................T.
Dec 03, 2007 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
