Question about Hisense TL-3220 Television
When I turn on my LCD TL3220 the screen shows a 3" x 6" silver box that says "no sync detected". I have checked the cable box and that seems to be working. Any suggestions
    Scholar:
  • 116 Answers
The word ''no sync detected' means that there is no video connection between the cable box and the TV set. Isolate the source of trouble by connecting to the TV a prevoius video source that worked properly e.g DVD player. You should also try to get a new set of video cables as the ones you have may be internally broken.
Please follow the installation instructions carefully especially the colour codes of the video and audio cables i.e yellow cable to yellow connectors of TV and cable box , Red cable to red connectors of TV and cable box etc.
good luck!
Posted on Oct 09, 2010
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Weak or no signal
perform an "auto-detect" if you are using hdmi interface, try a new cable. other than that, contact samsung.
Aug 30, 2012 | Samsung La22d400 22" Pal/ntsc Hd Lcd Wide...
Please help me, i got a hp 1730 lcd monitor. the problem is that the screen is turned white and no image is present like there si not sinc on the screen the menu is lose only a shadow on the screen and...
How many months or years of your monitor that you are using? Do you check the outlet, cables? It's seems that your monitor has a problem because i read your observation that your monitor seems to be replace a new one. That's the monitor's problem.
Sep 16, 2011 | HP L1730 (Carbonite, Silver) 17" LCD...
Screen is all Green
New cable box recently? If not, your cable provider has probably pushed a firmware update to your cable box. Green screens are very common with HDMI connection. From your symptom, I am going to take a guess that you are connected via HDMI. If so, switch to Component cables and your problem is solved. It's not the TVs fault... cable boxes seem to be the single largest problem child for HDMI compatibility. I hope this was of some assistance.
Apr 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Picture appears for 3 sec then shows no signal
HELLO MAKE SURE ALL THE CONNECTOR CABLES ARE TIGHT ON THE MAIN BOARD IF THEY ARE OK CHECK THE INVERTER BOARD FOR DRY JOINTS GOOD LUCK
SHAUN
Apr 27, 2009 | Westinghouse W4207 42 in. HD-Ready LCD TV
JVC GR-X5e camcorder, lens cap message. Does not show a picture.
It shows all menus, numbers and graphics on LCD, but seems like there's no picture coming through the lens. In both modes, video and still. It seems like it can not see anything as if the lens cap was on all the time.
Could this be a problem with sensor.. CCDs? Lens? Something else?
Feb 19, 2009 | JVC GR-X5 Mini DV Digital Camcorder
Cannot set screen width
Both the TV and the Cable box have Aspect(height/width) settings. You must confirme the setting on the cable box and then do the TV.
1. Set TV to Native, this should show image exactly as the cable box sends it.
2. change Aspect settings on the cable box until you get one that works
3. if you get a good one, then your OK. You will just need to find a setting between the 2 devices that work for you. Also, these settings may change automatically for the TV or cable box based on the channel
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Loss Sync
According to SharpUSA the problem with the "Loss of Sync" error message is that (most probably) the cables (between the box and the display) are not connected properly (so remove and reconnect them carefully, on both units) or a cable is defective.
Also, after you reconnect the cables try turning on the unit, if no success then depress the "clear" button on the external box (under the door on the front and on the bottom left and try turning on the TV again).
It is, most likely, that the cables are not seated properly. Reseat the cables on both the display and the external box.
Hopefully, this will clear the problem
if still does not solves your problem just replace all the cables connected between .u can get the new cables at radioshack web site.just place an order they will provide you. thanks.
Dec 14, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
477 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
