Question about Nordic Track NordicTrack Elite zi Treadmill
My Nordic Track Solaris will only work on speeds 1 and 7 and I can manually arrow the speed down when on 7. Other than that the other buttons are not working
  • eberl Nov 19, 2010
    anyone find a solution to this. i am having the same problem
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Posted on Feb 28, 2010
  • 218 Answers
SOURCE: Hello, I have a Nordic Track 2050, and got on this
console is bad no other alternative, check ebay for part
Posted on Aug 11, 2010
ercupa190
  • 12223 Answers
SOURCE: I have a Nordic Track C2050 treadmill and the key
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Cleaning: Remove the covert and spray the Key Pad with special spray( contact cleaner) for to remove dust, etc, very carefully, you mus unplugged the machine.
Posted on Nov 08, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a nordic trac
    • 2
    • 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Check the Optical sensor: if have it. very important!
http://www.youtube.com/watch?v=E-q-uS4t6so Watch this video.
Posted on Nov 09, 2011
Nordic Track NordicTrack Reflex 4500 Pro Treadmill - My belt speed is running about 60% of the speed displayed. What is causing that? Is there a reset feature?
The treadmill is set for kilometers, not miles.
With the stop button pressed, insert the safety key/magnet. This will display miles (or Kms) and hours of use.
There will also be a "M" for metric or "E" for english, or miles. Use the speed up/down buttons to adjust to "E".
Oct 01, 2017 | Nordic Track Exercise & Fitness
I have a Nordic track C2050 treadmill one day everything was working great the next day the only the #1 and #7 speed button worked decline up and down stopped working plus all program buttons not work
replace the old batteries ( if your system has batteries, clean the spring contacts from oxide, corrosion, etc with contacts cleaners) put a new batteries.
2) tight and clean the ribbon cables from display board
3) tight and clean the uppers and lower connector very well.
4) adjust the REED switch, tight the connector, clean it, and test the reed for open or faulty. see the diagram attached.
Oct 25, 2013 | Nordic Track Nordictrack C2050 Treadmill...
Nordic track 1000 works only on speeds 1 and 7
adjust the speed sensor, see the diagram attached. clean it and test it for open or faulty. Tight the connector very well.RUN the software calibration for easy diagnose, and fix it. God bless you3_22_2013_4_23_05_pm.gif3_22_2013_4_23_19_pm.gif
Mar 22, 2013 | Nordic Track NordicTrack Treadmill, A2550
My treadmill is telling me the wrong amount of calories burned and the wrong speed at which I am traveling. For example, I hit the button that says 6 mph, but the treadmill says I am running at 9.7 mph....
I had the same problem with my Nordic Track. I had somehow changed the display to metric readings.
Solution: Hold the stop button down while inserting the key, push the speed up or down button to change it back to english, remove key and you are good to go. Re insert the key and it should work fine. Hope this helps.
Nov 27, 2010 | Nordic Track Nordictrack Adventurer...
Nordic Track c2200 no speed signal. My NT c2200 treadmill behaved erratically briefly (sudden speed changes up and down) before quitting altogether. The console now behaves as though it's working but the...
It likely is the controller if it was speeding up and down erratically. Check the position of the reed switch to make sure it is positioned about 1/8" away from the magnet in the side of the front roller pulley. Run a diagnostic program as follows. Press the stop and speed arrow up buttons until you insert the key. Press the stop once or twice until you get to a screen with 2 sets of zeros. Now press and hold the speed arrow up button until one number set shows 8.5. The unit will go to full speed so be careful not to be on the walking belt. The other number set should top out shortly at either 10.0 or 12.0 based on whether your speed buttons go up to 10 or 12. If the motor races past your top number,( don't let it run that way as you may damage the motor), pull the key. If the readout is above or below your target by more than .4 and not flucuating a lot, you may need to tune the potentiometer on the controller. Counter clockwise turn with a phillips screwdriver turns the motor speed down. Be carefull not to short out the controller board by touching components with screwdriver. If not comfortable ask a friend with electronics background. If you turn the pot. too far it will break. It will not go a full revolution in either direction and tiny movements are recommended. Again I believe your controller needs replacing.
Oct 01, 2010 | Nordic Track Exercise & Fitness
The Nordic Track machine's controls seem to be stuck. If I press any button other than "3 mph", it fails to respond and nothing happens. However, when I press the 3 mph button, it will only stay at the 3...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Jul 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
Jul 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
Feb 27, 2010 | Nordic Track NordicTrack Treadmill, A2550
Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Jan 12, 2010 | Exercise & Fitness
Nordic Track NordicTrack Elite zi Treadmill Logo
126 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
