Question about Sony (DDU1632C1) Internal DVD Drive
MY ROM is a Sony (DDU1632C1) Internal DVD Drive. It doesn't read the DVDs and the CDs. I checked the data cable from the mother board and the power cable, cables worked for my CD rom but not the DVD/CD rom. The light in the DVD/CD rom is not on and it is more likely that due to some thing wrong within the DVD/CD ROM it doesn't recieve power, so need some help fixing it.
    Master:
  • 473 Answers
Check On the Back Off Your DVD-Rom itself look little pin with a black connector like a mini bridge... Look if it on position Master If So change your little connector to Slave Position.. The Restart your PC... Check also your IDE Cable for defect and all the pin inside your DVD connection ...Good Luck
Posted on Oct 09, 2010
I got A gateway essential 500 from a goodwill store and it has xp on it. It has the coa for windows 98. I also cannot get the cd-rom to read a disk even though its lights go on and it tries to read a...
Any EIDE (non Sata) interal drive should work on this computer. However, first I would check the internal cables on the drive to ensure the are plugged in tight (you may just have a loose cable). Check both the mother board end and the drive end.
Personally I would go puppy linux over 98, but that is me.
Hope this helps, have a great day and good luck.
Jul 22, 2011 | Gateway Essential 500 PC Desktop
Can read cds but no dvds
1) Clean your DVD lens with a cotton.
2) Change the data cable.
If these methods doesn't then there might be problem in lens.
Jul 08, 2011 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
I own eMachine Notebook e525 and it won't read any disks. I have tried multiple disks such as music cds, installation cds and video dvds. None of them read or open. There isn't even an icon for the...
> there is no icon for the CD-drive
Probably means that either:
* no electrical power is reaching the CD-ROM drive
* no "data" is being transferred to/from the drive
* the electronics inside the CD-ROM drive have "died"
Check the "power" and "data" connectors.
If necessary, replace the drive with a new CD/DVD reader/writer.
Jun 20, 2011 | E-Machines emachines (emachinees) CD-ROM...
I changed my motherboard and installed fresh copy of xp.Now my dvd rom doesn read dvds but only cds!should i install any driver utiity?
try to download some path file from the net for the motherboard then this may solve the dvd problem or you may have to change dvd drive
Nov 16, 2010 | LG (GCR8525BK) Internal 52x CD-ROM Drive
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
My cd drive will read cds but not dvds i try to istall somethig it wont work
Hi dkush29306,
while the other two posters have pointed out the obvious, that CDROM drives only read CDs, and that you need a DVD drive to read DVDs, i would like to add something to this.
I will asume you have a CDROM COMBO Drive, that *should* play CDRs and DVDs.
if you find it does spin CDs up and read them, but not DVDs then i might be able to offer some suggestions.
firstly, make sure there is no software conflicts (like two CD Writing softwares trying to use the CD Drive at the same time.. ). you shouldnt have to worry about drivers for the CDROM, as the default OS ones should suffice. but they may be corrupt. you could goto Device Manager if you are on Windows, and uninstall and reinstall the driver for the CDROM. it should find it automatically in the install wizard.
ok at this point i don't see how software could cause any other issue , so we should look at it being a hardware issue:
if you have the ability, try changing the IDE Ribbon Cable that connects the CDROM to the Motherboard. if that doesnt work, try changing which plug in the IDE cable the CDROM plugs into. these plugs usually have a blue plug at one end (motherboard end), and there is two plugs at the other end, or master and slave. keep the jumper pin on the CDROM set to Cable Select, so you dont need to change it to slave, when its plugged into the slave port, or master pin if set to the master port.
finally, if none of that helps (and it probably won't ) you might find that the actual fault is due to the laser in the CDROM not focusing tightly enough and therefore cannot read the data on a DVD ROM because of this. the only way to tell if this is ok or not, is to plug it into another computer and see if it can read DVDs.
you might just be better off spending 20-50$ and buying a new CDROM Combo drive from your local computer hardware store.
Jul 17, 2009 | Computers & Internet
After I reinstalled my pc, the toshiba dvd-rom (sd-c2502) only plays cds, not dvds.
Try re-installing your the driver for your dvd rom. Then try to put different dvds and check if it can read from your drive. If problem remains, I suspected it's your dvd rom is faulty
Jun 02, 2009 | Dell Computers & Internet
CD is not recognised by the CD Drive
your dvd writer lens needs to be cleaned by a lens cleaner...
May 28, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Sony combo drive
Most probably, the drive is defective. I would return it.
Sep 24, 2006 | Sony (DDU1632C1) Internal DVD Drive
Sony (DDU1632C1) Internal DVD Drive Logo
47 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
