Question about Microsoft Xbox 360 Console
Disk drive problem
My xbox 360's disk drive opens, but the massage shown on the screen is "opening" and then it automatically closes. Also disk tray doesn't open sometimes. please give me any solutions. Thanks in advance.
    Scholar:
  • 65 Answers
Check to make sure nothing is blocking the drive opening all the way if something is the drive will auto close to not damage the drive if that is not the case then check all the controllers to make sure non are pressing any buttons when you try. and try connecting your xbox 360 to xbox live to make sure it is fully updated if it is not any of that then it sounds like it is a hardware issue and you will need to call
1-800-4MY-XBOX
International (direct dial to U.S.): 425-635-7180
Hearing Impaired (TDD device): 1-866-740-9269 or 425-635-7102
Hours of operation (every day):
9:00 A.M. to 1:00 A.M. Eastern Time
6:00 A.M. to 10:00 P.M. Pacific Time
-or-
go to http://www.xbox.com/en-US/support/?WT.svl=nav
Where you can try typing "try closes" or something along thos lines.
Posted on May 30, 2008
  • Ariel Lothlorien
    Ariel Lothlorien May 30, 2008
    Try also Touch the eject button on the PLAYSTATION®3 system front for 10 seconds
    or longer to force the disc to eject. After removing and before
    reinserting a disc into the PLAYSTATION®3, turn off the system, and
    then turn on the system again to resume use.
    -Rel
Xbox 360 console says open tray
I assume there is a disk inside and the tray is closed? Clean the disk, or like my MW2 disk which is cracked and does the same thing; opening and closing the tray, it will recognize it after a while.
Sep 27, 2011 | Microsoft Xbox 360 Console
Open tray comes up when loading a game?
Try tapping above the disk drive or if that doesn't work open the tray take your disc out close the tray. open the tray put ur disk back in and close the tray again.
Mar 15, 2010 | Microsoft Xbox 360 Elite Console - Black
Xbox 360
Most likely your disk or dvd drive is dirty. Run the disk through a disk cleaner and run a dvd cleaning disk through your drive.
If that dos not work, try removeing disk, close drive, turn off console, unplug power supply, wait 10 or 20 seconds, then reconnect power supply and try again.
If that fails, assumeing other disks will read, your disk may have a major flaw. You can check with your local game store, they often have a machine that may restore your disk, (most places that I know of charge like 1 or 2 $).
Mar 10, 2010 | Microsoft Xbox 360 Console
Disk tray automatically opens
Make sure there is no debris inside of the drive. With the opening of the drive towards the floor, shake the system to make sure that if there is any debris in there that it will come out. Also make sure that there is no broken cd's in the drive cause that will cause the door to open and close.
If that doesn't work, the door might need to be re-aligned. Clean the door with glass cleaner, the amonia in there would get any dirt or stickiness off of the door.
Jan 01, 2010 | Microsoft Xbox 360 Console
Xbox 360 disk drive problems
Yes , open up your CD drive remove
the top cover ,turn the belt on the pully
CC like you did before to pull the tray out
till it stops. There should be two small tabs
on etch edge at the end of the tray lift them
and pull this should relase the tray from
the drive . now look down in the frount
of the drive there are to leaf switches on
etch side the they should be straight.
the cats may have bent one of them with
his paws . I guess the cat will stay away
from your xbox now.
hope that help a little
Rob
Sep 20, 2009 | Microsoft Xbox 360 Console
Open tray on xbox when it's closed
when the tray is closed and it does not
see a cd it should say open tray
The problem weak or dead laser
laser are chep 30.00- 40.00
and not to hard to swap out.
second it may be a bad drive motor
or bad spindel motor .in that
case you will to buy a new
drive and swap out the P.C. board
from the old drive to the new one
Rob
Sep 16, 2009 | Microsoft Xbox 360 Console
Xbox says open tray when game is in
This means that either the lens inside it is scratched or dirty.(Some kind of compressed air can might work). Or the disk is scratched..;-; Damn 360s..
Jun 19, 2009 | Microsoft Xbox 360 Console
Xbox 360
You will need your dvd drive replaced. We can do this for you.
www.videogamerepairservice.com
Dec 30, 2008 | Microsoft Xbox 360 Console
360 disk tray
What I did was took apart my Xbox and put the disc tray back on the tracks, carefully lifting it over the circle thing in the middle. When I lay my Box down horizontally, it opens and closes fine.
Jul 27, 2008 | Microsoft Xbox 360 Console
Xbox 360: disk drive will get stuck...may be leading to disk not spinning
If you ever open the disk tray and then the power source is cut, the tray will try to ''autofix'' itself by making whatever state it was at the default position. This doesnt sound like whats going on for you, though.
If you can turn your 360 on and go to the main screen, try opening it with the ''open tray'' button on the bottom of the main screen.
If that fixes it, your problem is a faulty disk tray button.
If the tray still does that with the xbox main menu button, then its a mechanical thing with the tray.
Go to walmart and buy one of those air spray bottles (like an airsol can to clean dust out of PCs) and spray it into the 360 tray once it is opened. Aim the spray on the sides, what it sounds like is dust or something collected on the gears of the disc tray. If you have your 360 on carpet or a dusty surface this is probobly the problem.
Thats about the only thing you can do without opening the 360 up yourself (IF ITS STILL UNDER WARRANTY DONT OPEN IT) that will void the warranty. So if the airsol spray doesnt do it, then send it in to microsoft.
hope that solves it
-erk
Jun 18, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
