Question about LG WM-2277HW Front Load Washer
The front slide drawer where you put the detergent is stuck and will not open. What do I do?
    Problem Solver:
  • 7 Answers
Just give it a good yank, if it still doesn't come out get a stronger guy to pull on it.
Posted on Oct 09, 2010
I have a GE Adora front load washer and my detergent drawer is stuck shut. It won't open no more than an inch. Is there a way to remove it w/o breaking the drawer, in order to get the items out of it?
sounds like something is block the draw from open all the way.
Try using a metal coat hanger or a paint stir hand from Home depot the very long one.
slide along the open part of the door.
Apr 28, 2015 | GE Washing Machines
Washer detergent drawer will not open...drawer lock or detergent cup?
Something has jammed the drawer closed. You will need to access the top of the dispenser.
Remove the 2 screws holding the top lid in back. Slide the top lid rearward and remove.
Pry open the top of the dispenser top and using a small screwdriver, unsnap the lid snaps.
This will release the drawer and you can clean out any debris that caused it to jam up.
Good luck.
Jul 08, 2011 | LG WM-2277HW Front Load Washer
Water is pouring out of my dispenser drawer
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Cannot open the detergent drawer. It is stuck.
No simple solution other all you can do is try pushing it back in and pull it out. If that fails you will need to force it there is no way to get into it, LG parts are not expensive if you happen to break it.
Apr 16, 2010 | LG WM-2277HW Front Load Washer
LG Front Loading washer detergent drawer is jammed and will not open
you're in a bad spot. you will need to remove top metal panel of washer; and carefully separate the drawer housing a little and wiggle the drawer out. one of the compartments in the drawer popped up and jammed the drawer.
Feb 15, 2010 | LG WM-2277HW Front Load Washer
Laundry detergent drawer stuck
I had the same problem - the fabric softener cup cam loose and I had to break it to get it out and the new drawer cost me about $65 to replace. I hope you made out better than I did.
Dec 13, 2009 | LG WM-2077C Front Load Washer
The slide out drawer for detergent and softener will not open, stuck from the inside. I think one of the trays inside the drawer somehow has moved up blocking the drawer from sliding out.
remove the lid of the washer. there are 3 torque screws you can either use a t15 or a 7 millimeter. locate the dispenser there are clips on the lid of the dispenser push in and lift up. be careful you will be able to get your drawer open. let me know if you need any more help
Aug 14, 2009 | LG WM-2277HW Front Load Washer
Front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Mar 26, 2009 | LG WD-16115FD Front Load Washer
Detergent drawer will not open
Here's a possible solution: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
Jan 12, 2009 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
74 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
