Question about Gaggia Caffitaly K111 Coffee Maker
I have broken the plastic holder for the coffee pods and need to buy a new one form my K111-d - can you tell me where I can get one from ?
  • 3 Answers
After a lot of searching, I have just ordered two of these from this site:
www.homewares.co.uk
Part number is CCH1 and they cost £9.50 each. Good Luck!
Posted on Dec 31, 2010
Can I adapt a Francis francis x1 to take ese pods?
My X1 came with an ESE pod holder and a ground coffee holder so they are definitely available.
Dec 02, 2012 | FrancisFrancis! Coffee Makers & Espresso...
My capsule / pod holder is broken. Where can I get a new one, and how much do they cost ? Thank you
hi,
contact ylavoie@sybco.com. they are located in canada and are the distributor for caffitaly. they have a model called ocs3000 that has exactly the same capsule holder.
ciao
Sep 26, 2010 | Gaggia Caffitaly K111 Coffee Maker
When i turn on the machine, green light is on, pod inserted, but the coffee wont come down into cup. This happened before, apparently it was air locked. i tried the coffee button and the steam button at...
When I have this problem with my machine, it is usually because the two parts of the capsule holder are not fixed together properly. Take it apart and then twist it back together again and make sure the handle is pulled all the way down. This part of the machine is very fussy and you might have to do it a couple of times. The machine will not dispense coffee if the capsule isn't seated properly!
I usually find my machine is less noisy after it has been de-scaled. We were told to de-scale every 4 weeks to keep the machine running well. Good Luck!
Aug 25, 2010 | Gaggia Caffitaly K111 Coffee Maker
K--cup holder (pod holder is broken need another
if you are talking about the black funnel part? then this site sells them http://stores.ilikenew.com
May 13, 2010 | Keurig Platinum B70 Coffee Maker
Philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
Dec 27, 2009 | Philips Senseo HD-7810 Coffee Maker
Metal pin does not poke thru the pod
Do you need the top or bottom one? either way we have them here; http://www.igotsweetdeals.com
Oct 16, 2009 | Keurig B50 Coffee Maker
My senseo machine doesn't seem to produce the crema layers even though i've followed all the instruction
You may find that the plastic disc on the bottom of the pod holder is not sealing (there is an O ring) ,if the amount of coffee dispensed is more than usual that will be the problem,just buy a new pod holder.
Oct 06, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo coffee problem
The pod holder has an O ring to seal the black plastic disc in,if it is not sealed you will end up with more volume and a weaker coffee without the foam,either knock the disc out and try and seat the O ring and then knock it back in or buy a new pod holder,I had this same problem
Nov 30, 2007 | Philips Senseo HD-7810 Coffee Maker
Gaggia Caffitaly K111 Coffee Maker Logo
249 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
