Question about Nautilus Ntr 800 Treadmill Lift Motor
My nautilus ntr treadmill doesnt work when i turn it on. on the screen it flashes entr h95 and then it clicks and says "err" and in the small window to the left it says L5. Any suggestions?
3 Suggested Answers
  • 11 Answers
SOURCE: Treadmill belt adjustment
There are two bolts on the back of the treadmill. Turn the right side clockwise to make the belt go left, turn the left side clockwise to make it go right. Never tighten more than 1/2 turn at a time, and do this while machine runs at 2-3 mph. Belt should be just tight enough to not slip. If your belt is really tight and it still slips you have other problems.
Posted on Feb 09, 2011
ercupa190
  • 12223 Answers
SOURCE: speed is off on nautilus exp 1000x treadmill
Please use your calibration software for recalibration your fitness according with your owner manual. See the instruction too below the hood. and proceed for fix it.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a
Posted on Dec 19, 2011
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
Nautilus T515/T516 treadmill stopped suddenly while I was running on it. I heard a snap right before it happened, so that made me check the belt, but that was fine. The screen reads E1 when I turn it on....
see the video and lube the deck belt. Use silicone or wax see your owner manual.
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
God bless you
May 30, 2013 | Exercise & Fitness
Calibrate nautilus T914
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step. The Calibration seq
God bless you
May 22, 2013 | Nautilus T914 Commercial Series Treadmill
Nautilus NTR 800.6 Treadmill. I can go up on speed and incline but not back down?
please RUN the software calibration, for easy diagnose, troubleshooting, and fix it.
Test the speed sensor, for open or faulty, clean it, and tight the connector very well. see the diagram
Happy New Year. God bless you
Jan 01, 2013 | Exercise & Fitness
Lubricant belt zoom
go to www.fitnessrepairparts.com or www.treadmilldoctor.com and buy it the LUBRICANT belt.
God bless you
Jul 21, 2012 | Nautilus Ntr 800 Treadmill Lift Motor
I have a Precor 9.33i Treadmill. It works perfectly until I start to walk/run on it and then it shuts down. What is causing this?
LUBE THE deck belt, this happen because the system protect the electronic system, with shut down.
2= LUBE THE ROLLERS BEARINGS TOO
3= measure the input voltage motor, if there are the motor need repair
4= measure the output voltage board, for input voltage motor, if there are NOT the boar is faulty.
see the block d
God bless you
Jul 19, 2012 | Nautilus Ntr 800 Treadmill Lift Motor
Nautilus NTR 800 fuse kick out when I start to run
See my personal TIPS for HELP , and see the diagram.
there varios reason. a) the main switch b) some wires touching the carcase c) ground defective d) some components in the power supply in short.
Try to RUN the software calibration for diagnose and troubleshooting.
You must shure to put the correct size amp, and voltage for the fuse, and the same type!.May be you need assistance from some service tech
sincerely. God bless you
Apr 28, 2012 | Exercise & Fitness
Jan 03, 2010 | Nautilus Exercise & Fitness
Nautilus Ntr 800 Treadmill Lift Motor Logo
49 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
