Question about Honeywell Heating & Cooling
The gas valve on my Honeywell Glow Worm Space Saver Mark II boiler has failed. The part number on the valve is V8600A 1024 2. It is a 24v valve. I have seen several on the web that look similar but have slightly different numbers. How critical is to buy a replacement with an identical part number? Which alternatives are compatible? Andrew Blundy
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. Use a 3606c this is a universal type that will work for you.
Posted on Oct 09, 2010
What should ther honeywell relay read in ohms on a r8222u 1006
did you check power to the gas valve? Pilot lit? Or electronic pilot on? Need more info on boiler.
Nov 05, 2011 | Honeywell Programmable Thermostat Heater
Service manual for glow worm boiler micron soff
Can you give a model number and more info? I think you mean a micron 60ff in which case it is here: http://www.glow-worm.co.uk/stepone/data/downloads_sd/8d/00/00/micron-60ff.pdf
Jan 02, 2011 | Heating & Cooling
I have a Trianco Heatmaker Mark II and we recently had a pressure safety valve and expansion tank replaced and I still notice water around the bottom of the boiler and every so often we hear a whining...
There is a sensor located on the top of the domestic water tank that quite often fails. It has a very thin membrane between the water heater and the atmosphere. Have a technician check this sensor and please start thinking about a replacement boiler. Here in the Northeast we have had more than our share of deaths associated with the venting of this make boiler.
Feb 09, 2010 | Jandy TELEDYNE LAARS GAS VALVE, PROPANE...
Glow worm 45 60 boiler
You have to have 12" clearance on all sides.
Apr 02, 2009 | Water Heaters
Honeywell T403A1174 suddenly doesn't appear to call for heat
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Jan 31, 2009 | Honeywell Water Heaters
Thermocoupling on a Honeywell Economy Plus EP50B Boiler
the thermocouple most likely plugs into the gas valve, the box with the gas control on it.
Jan 10, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
How water problem
Your should be able to find the information here. Don't forget to check under discontinued products. www.glow-worm.co.uk
Dec 03, 2008 | Water Heaters
Heating & Cooling Logo
265 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
