Question about GE JGBP24 Gas Kitchen Range
My oven gets too hot - when I attempted to bake a cake, within 10 minutes the cake was burned and the oven was WAY too hot. We just replaced the ignitor and now the oven lights, but the temp is way too hot... how is this adjusted?
housejess
  • 317 Answers
SOURCE: My gas oven overheats and burns my baking. With
bad thermostat.....buy new at lowes .....its inside the oven.....usually at the top of oven..looks like copper rod with copper wire ....easy to change...buy at lowes or homedepot
Posted on Nov 16, 2009
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
SOURCE: Similar problem but ignitor replacement did not fix mine
try the gas valve behind the storage drawer. it may be closed. that was my problem.
Posted on Aug 25, 2008
MNTECH
  • 1543 Answers
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
Posted on Nov 23, 2008
SOURCE: GE Profile Spectra JGBP85WEB5WW Taking Too Long to Reach Temp
GE use and care manuals
Posted on Dec 06, 2008
Why does the bottom of my cakes burn before the center is done?
Because your oven gets too hot on the bottom part. Use a rack to position your cake in the centre of the oven or - if the bottom of the cake still burns - insert a baking tray between the bottom of the oven and the rack on which you bake the cake on.
Sep 19, 2014 | Baking
Baking cakes and quiches
i use the micr-convention mode to bake and preheat it at 200 C ,the cake rises unevenly and falls unevenly .i open to check if the cake is done .why does it rise unevenly and why does it fall ?
Jul 18, 2012 | Microwave Ovens
I lost my instructions for the recipes and i don't know how to make the cake mixes
I have the recipe for yellow cake from the handbook:
preheat over for 15 minutes and spray pans with cooking spray
1. pour contents of yellow cake mix into bowl and stir to break up any lumps. 2. add 1.5 teaspoons of water and stir to form batter 3. pour batter into baking pan and spread evenly. 4. place pan in baking slot of oven and use pusher end of pan tool to push it into baking chamber. Do not use your hands. 5. bake cake for 12 minutes. 6. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 7. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. Transfer cooled cake to a plate, turning over so bottom faces up.
frosting 1. pour contents of frosting mix into bowl. 2. add 1/2 teaspoon of water and stir until smooth. For thinner frosting, stir in a few extra drops of water. 3. spread frosting over cooled cake.
Sugar Cookies
1. pour contents of sugar cookie mix into bowl and stir to break up any lumps. 2. add 3/4 taespoon of water and stir to form dough. 3. sprinkle your hands with flour and shape dough into 6 small balls. 4. flatten 3 cookie balls and place in baking pan. 5. place pan into oven and use pusher end of pan tool to push into oven. Make sure both metal doors are closed. 6. cook for 10 minutes. 7. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 8. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. 9 repeat steps 4-8 to make remaining 3 cookies.
those were the basic recipes in the handbook. Hope that helps
Jul 25, 2011 | Hasbro "easy Bake Oven and Snack Center"...
Why do cakes sometimes collapse while baking?
helllo dis.... There are many things that can cause cakes to fall in the middle.... Jumping, etc., around the baking area is unlikely to be a problem except with very delicate sponge or angel food cakes. More likely, cakes fall when the crust appears to be done, but the batter is not baked through the middle. An uneven baking temperature is a frequent culprit; check the temperature of your oven with a separate baking thermometer, and be certain that your oven holds a steady heat through the entire baking period. Some older ovens preheat properly, then cycle off and drop the temperature after 15 or 20 minutes, which causes the uncooked portion of the cake to fall.
Less likely but possible problems could be inaccurate proportions of baking powder or baking soda if the cake is made from scratch. This could occur with cake mixes if sour milk or buttermilk is used instead of regular milk; the additional acid in sour milk requires additional baking soda to rise properly. Eggs that are not beaten properly, or perhaps beaten too much for the type of cake being made, might also cause problems. Joe
Mar 12, 2011 | Tecnik Ovens
I hv got a ifb microwave oven 23sci with grill , i have tried baking cakes many time and every time it gets burnt. The sides get baked and the central zone is unbaked. MY method is , I take a glass utensil...
You should be using convection mode first of all. It's not clear from your post if you are. Also looks like you're oven is baking at higher temperature than it says. Try 170 degrees for 13-14 mins instead.
Feb 28, 2011 | KitchenAid KHMC107BT Convection/Microwave...
Need the recipe for the cake mix that come with the oven
This is just one of many I found at this website http://www.lynettee.com/kidfood10.htm
Children's Chocolate Cake Mix
1 cup sugar
3 tablespoons unsweetened cocoa powder
1 1/2 cups all-purpose flour
1 teaspoon baking soda
1/2 teaspoon salt
1/3 cup vegetable shortening
In a medium bowl, combine sugar, cocoa powder, flour, baking soda and salt. Stir with a wire whisk until blended. With a pastry blender, cut in shortening until evenly distributed and mixture resembles corn meal. Spoon about 1/3 cup of the mixture into each of 11 small containers with tight fitting lids or Ziploc bags. Seal containers. Label with date and contents. Store in a cool dry place. Use within 12 weeks. Makes 11 packages of Children's Chocolate Cake Mix for Easy Bake style oven.
To Use:
1 package cake mix
4 tsp. water
Mix together and stir with a fork or spoon until blended and smooth. Pour mixture into greased and floured 4 inch round miniature baking pan. Follow directions for child's oven, or bake in mom's preheated 375* oven for 12 to 13 minutes. Remove from oven and cool in pan on a rack for 5 minutes.
Invert onto a small plate and remove pan. When cool, frost with Children's Chocolate Frosting. Serves 2 children.
Enjoy!
Jan 29, 2011 | Fun Rise Disney Princess Cool-Bake Magic...
When baking the oven doesn't bake evenly and always bakes quicker than the time on recipes. Items burn and the middle is raw. Can the oven be recalculated to work better?? John
Electric ovens are always different from gas ovens. You have to set the temperature on average 10-15 degrees lower and watch out 15 minutes earlier if you are baking cakes, 5 mins for cookies etc. Always bake in the centre of the oven. use a metal bowl of water in another tray which may help balance out the temperature
Jan 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
How to set the temperature on the KitchenAid Superba oven/convect
A separate oven thermometer is absolutely necessary in baking. Something similar to this would be cheap and easy. http://www.bedbathandbeyond.com/product.asp?order_num=-1&SKU=10161738
Or you could go for a digital one with a probe.
Apr 08, 2009 | KitchenAid Architect Series KEBC107KSS...
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Trouble baking
Sounds like it's running too hot. Check temps. May have a stuck relay on board. Run oven and check to see if bake element is cycling off when it reaches temps. It should stop glowing within
15 minutes from start. If it doesn't you need a relay board most likely.
Nov 04, 2007 | Jenn-Air JJW8330D Electric Single Oven
GE JGBP24 Gas Kitchen Range Logo
202 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
