Question about Eljer & Elongated Toilet Bowl
I have a euro mono back to wall toilet and teh toilet seat has come loose. I have detached the seatgfrom its fixings but cannot see how to ighten the fixing as the screw is not visible nor accessible
  • Mark Adkin Jan 30, 2012
    I know its a long time since this question was posted but I had the same issue and have just fixed it. Remove the toilet seat by pushing in each of the two release buttons on the hinges, then lift. Where the hinges located are two circlular receivers, both have a metal cap that can be removed using a small flat head screwdriver or similar. This reveals a large cross-head bolt head on each which you can tighten. I suggest nipping them up not overtightening just in case you damage the bowl. At least once you know where they are you can re-tighten another day! Then reassemble (remembering to put the caps back on first)... I hope this helps someone - I spent ages looking for the answer on the internet only to find it all out myself. Good luck...
Posted on Jan 30, 2012
    New Friend:
Hi, i have the same issue as my seat is loose. i have removed the seat which leaves a metal plate with two round pins sticking uip. there is no access to the back of the toilet or underside where the bolts would be as its a back to the wall toilet. any ideas?
Posted on May 28, 2013
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
  • 43 Answers
SOURCE: unable to fit a toilet seat
do you mean a water seat? like where you would install a water line? or a a seat you actually sit on?
Posted on Nov 16, 2008
  • 10865 Answers
SOURCE: elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Posted on Jan 31, 2009
radar001
  • 1051 Answers
SOURCE: loose toilet seat
If the screws don't tighten the either the screw threads are stripped or the attachment nut is stripped. Take the screw and nut to any hmoe repair center and get new ones. remember don't over-tighten then screws as this will crack the unit.
Posted on Feb 11, 2010
  • 3600 Answers
SOURCE: How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Posted on Jun 01, 2010
How do I remove toilet seat?Appears to be 2 bolts with top access only.
rak soft close toilet seat - YouTube
? 0:31
https://www.youtube.com/watch?v=RLssM9BYJjg
Oct 9, 2013 - Uploaded by Paul Hooker
rak soft close toilet seat. ... How to remove and change a Villeroy & Boch toilet seat with top fixings ...
Rak Series 600 Back To Wall Toilet - YouTube
Nov 29, 2015 | Home
I have a bathstore euro mono soft close seat. The hinge has come loose one side and needs to retightened. However, I cannot remove the seat from the hinge as the release button will not release the hi
Try using a knife to slide in the under-part of the release button and pop it off. If that doesn't work, you might have to brake it.
Oct 10, 2014 | Home
Gala toilet seat
Assume its an old Gala Marina model which is screwed into the cistern.
Fieaga in Drogheda Ireland can supply. Delivery about four weeks. I have just got one. They have a website with contact info. Price was Euro 120. Too expensive but no choice
May 31, 2013 | Home
I have a toilet which is a one peice. The toilet seat has come loose and the bolts have dropped to the floor. I can not fit the seat back as the pieces that i would use to tighten the seat are on the floor...
In no case would you ever have to pull a toilet to get to seat bolts.My guess is if you take the tank lid off and look inside there youll see the bolts . If not you can buy another toilet seat with new bolts or just get the bolts to fit your seat and tighten it down.Forget about the old bolts unless they become a problem with the flushing of the toilet. Hope this helps
Jun 22, 2010 | Home
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
I have a Jika Mio soft close seat with a loose hinge which I cannot reach due to closeness of pan to wall!!
The top lid of my soft close toilet seat slams shut.How do I adjust Jiko Mio close coupled toilet.
Mar 27, 2010 | Villeroy & Boch Home
Eljer & Elongated Toilet Bowl  Logo
1,818 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
