Question about Goldstar R1003 Air Conditioner
The unit was working then shut itself off and will not start. The unit trys to start but only humms that that shut off after a couple of seconds.
Compaq presario shutdown
you might need to replace the monitor
Sep 21, 2013 | Computers & Internet
Shure PG58 microphone shuts itself off after a few seconds.
Sounds like it needs repaired. Call Shure Service at 800-516-2525.
Mar 16, 2013 | Shure Audio Players & Recorders
My 70 series just humms
What is the complete model number of your unit?
Dec 05, 2012 | Washing Machines
My '99 Ford Ranger (while on cruise control) just shut off while I was driving. Electronics work but engine shut off. Engine turns over but doesn't start up. Any ideas?
2 things to do. Listen at the tank for the fuel pump to humm for 5 seconds when you turn the key to ON.
2. Spray some starting fluid into the throttle body and see if it starts for a few seconds then. If yes, it is probably the pump, slim chance it's the fuel pump relay.
Dec 23, 2010 | Ford Ranger Cars & Trucks
I have a kenmore 90 plus series model # 11068972892............... when i push start button the dryer motor will humm and mabey start to run or it will just humm and not run at all..if it...
Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
Sep 06, 2010 | Kenmore Dryers
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Car trys to start but quits a second after
It could be anything. Any way you could give me more details. The more, the better. A couple of ideas are the ignition switch or maybe the oil sending unit. I dont know if it eventually start, engine light on while its running, started coming on before starting issue, vehicle maintenance history. Let me know.
Apr 28, 2009 | 1995 Chevrolet Camaro
Kenmore frt ld dryer, motor hums ,shuts off, does not trip brkr
see it all the time,the motor is getting to weak to start,that's why you get the hummming sound sometimes,you can check your locak used appliance store or maybe ebay has one,your model number is inside the dryer door,to sum it up it's the motor,let me know now you make out-mike
Apr 11, 2009 | Kenmore Dryers
My 90 + goodman starts up then when blower starts the flames go out i can hear a clicking in the bottom of the unit and the exhaust fan shuts off then i can hear it kick on and the furnace trys to start up...
if you get a flame for about 2-3 seconds, than is goes right out, it would be a flame sensor, get some fine sand paper and clean it reinstall and should work fine, the flame sensor would be on the left hand side normally on goodman , looks like a stright rod with only 1 wire going to it, normally a white wire.
Jan 02, 2009 | Heating & Cooling
Goldstar R1003 Air Conditioner Logo
21 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
