Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
THE GLASSES AFTER THEY HAVE BEEN WASHED IN MY DISHWASHER COME OUT AS SMOOKY OPAQUE
  • LG Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Posted on Oct 09, 2010
Dishwasher fault finding
you water level in your dishwasher is probably low if you change your water valve and run a dishwasher cleaner through it that will solve your issue
Dec 30, 2013 | Beko Dishwashers
Glasses look awful after being washed, maybe I need maintanance
If you have hard water glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. After that it is recommended to use a little vinegar in each cycle to maintain the clarity of the glass.
Feb 25, 2011 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Glasses in top rack are covered by an opaque film. Seems like the insides are collecting the most. I've tried the white vinegar wash and it worked the next time but the following load was worse.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Dec 18, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
What causes a film to be left on glasses after being washed in dishwasher?
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Aug 07, 2010 | Kenmore 15899 Built-in Dishwasher
Top Dishes not coming clean
Clean ot replace circulation pump.
Clean or replce hoses
Jan 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Glasses Smell after Washing
if you are using the heater to dry them .. have you ever washed anything plastic that may have melted onto the heater element? You might try flushing the dishwasher with white vinegar and then run a set of glasses in the energy efficient mode ( no heater to dry them)..just air dried.. See if any of these ideas rid the chemical smell you have observed... Hope this helps///
Aug 29, 2008 | Bosch 24 in. SHE43C05UC Stainless Steel...
SMELLY GLASSES
Suggest running a rinse cycle once or twice, if this does not help, try mixing one or two table spoons of baking soda into 500 ml - liter of warm water and wipe down the interior of your dishwasher.
After wiping down, run the rinse cycle again before attempting a normal wash.
Try to avoid washing pans with glassware, as some coatings ( that may be dishwasher safe ) have a tendency to react with the detergent, thus creating an unclean smell on other utensils, plates or glass.
Wash pans on their own, or in a conventional sink.
Jan 12, 2008 | Dishwashers
This is an maytag
If the cloudyness on the glasses can't be washed off by hand and seems permanent, the glasses are eched. Usually caused by hard water or minerals in the water. The only thing that helps is using a good rinse agent.
Oct 16, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Foggy Glasses
yes i think this is the cause of your problem
i suggest you run washer a couple of times empty but add soap
Aug 14, 2006 | GE 24 in. GSD2000Z Built-in Dishwasher
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
53 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
