How do i replace a timer switch on a kenmore 700 series washer
SearsTechToo
  • 261 Answers
SOURCE: Kenmore 70 series washer
Does it hum or click? If it clicks your coupler is out or a hum could be a faulted gearcase.
Posted on Aug 28, 2008
onthejob5130
  • 640 Answers
SOURCE: Timer Replacement
theres 2 screw at each in of unit,,,if you dont see the uou have corner caps,,just pull them off wit your hand,,,..front right and left console coeners..onthejob
Posted on Feb 01, 2009
localwonder
  • 6784 Answers
SOURCE: I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Posted on Mar 03, 2009
  • 107 Answers
SOURCE: Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Posted on Mar 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 700 series washer only operates in gentle cycle
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Posted on Sep 12, 2010
How to remove the timer?
HERE IS A LINK TO YOUTUBE VIDEOS CONCERNING YOUR WASHER..... BUT I DIDNT SEE ANYTHING ABOUT A TIMER. I HAVE REPLACED KENMORE TIMERS....PULL OFF THE KNOB...
REMOVE THE SCREWS THAT HOLD DOWN THE COVER WHERE THE TIMER IS LOCATED.... ONCE YOU HAVE THE COVER OFF..... GET YOUR PHONE OR CAMERA AND TAKE A PICTURE OF WHERE ALL THE DIFFERENT COLORED WIRES ARE LOCATED...SO YOU WONT BE LOST WHEN YOU INSTALL THE NEW TIMER.
https://www.youtube.com/results?search_query=HOW+TO+REMOVE+A+TIMER+Kenmore+Series+70+Washer+Motor+387780
Dec 02, 2014 | Kenmore Series 70 Washer Motor 387780
My Kenmore washer is not draining or rinsing
Check the lid down safety switch. On the lid there is a small spike that goes through a hole when the lid is down.
Under the hole is a switch that allows the timer to advance and the washer to spin only when the lid is down. Two screws hold the switch in place and the plastic switch will sometimes break and be hanging by the wires.
In other words, it is the timer. That is stopping the advance. You may have to replace the timer.
How to replace the timer in Kenmore top load washer
Aug 27, 2017 | Kenmore Washing Machines
Kenmore 80 series washer, replaced lid switch already, will fill, wash (agitate) but stops before draining and spinning and will not run. Is the timer the next step for replacement? Model: 110.29852991
First check the continuity of the wires in the lid switch and the switch itself. Make a jumper wire to attach to the lid switch connector on the washer cabinet and set it to spin. If still no spin,replace the timer.
Aug 14, 2009 | Kenmore Washing Machines
Mar 11, 2009 | Kenmore 24032\24036 Top Load Washer
Timer Replacement
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 700 Series - No drain/spin
WOW, THIS IS AN EASY FIX, YOUR LID CONTROL SWITCH IS BAD, YOU CAN EASILY BYPASS THIS OR REPLACE IT, I THINK THE PART IS AROUND $25
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
It won't agitate
after it fills do you hear any sound and does it go to spin on its own or do you turn the timer your self it could be a bad pressure switch thats what we are trying to determine
Feb 12, 2008 | Kenmore 24642 Top Load Washer
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
