Question about HP 6530b Notebook
The input on the laptop where i stick the charger inn isn't working, what do i do?
  • 2,567 Answers
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop
Posted on Oct 09, 2010
Not charging when charger is plugged in.
if the battery is above 90 percent this is normal , if it isn`t then you charger - or nb plug malfunctioned and is not recognized as genuine hp charger and will only power on to prevent damage to battery. TRY NEW CHARGER
Feb 26, 2014 | HP EliteBook 6930p Notebook PC
When i connect my toshiba charger and my laptop goes off but i have tried different charger still thesame
Normally this should be a charger issue. I personally use quite a high-end charger. You should consider when you buy laptop charger that the wrong voltage/current could mean your computer can't turn on.
However, if you're 100% sure the laptop charger isn't at fault, then I recommend getting it checked out by a repair shop, because it may be a main-board issue where your laptop is actually not accepting the power from the supply, which is potentially terminal.
Oct 15, 2012 | Toshiba Satellite M35X-S163 Notebook
With a new motherboard installed, am still having problems with AC power cord and battery. I know battery is getting to end of it's life.Power cord will not power laptop by itself. Laptop will onl
Output of 19 Volts DC at 6.3 Amps is correct. (It isn't the Amperage you have to be concerned about so much. It is the Voltage. Voltage is correct)
Mounted on the motherboard of your laptop is a power correcting chipset.
This chipset senses when the laptop battery needs a trickle charge, or a full charge. It also senses when the laptop is to run straight off of the battery, or the AC adapter. (Charger)
With a Battery being at the end of it's 'Life Cycle', you may be overtaxing this chipset. Can't sense that the laptop needs to run straight off of the AC adapter. Tries to constantly charge the battery.
Replace the Battery.
Or the motherboard isn't worth poo-poo, and has a bad power correcting chipset.
(Don't care if the motherboard is new. Lemons are made)
Some examples of chipset's used in this mode, I am referring to;
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://html.alldatasheet.com/html-pdf/85156/VISHAY/SI4925BDY/183/1/SI4925BDY.html
For additional questions please post in a Comment.
[ Also would like to ask what the diagnoses was, for motherboard replacement ]
Regards,
joecoolvette
Mar 18, 2012 | Toshiba Satellite A75-S2112 Notebook
It has power but no display
There isn't enough details, but:
Please unplug the battery (remember to disconnect the charger),
then, hold on the power button for a minute,
after that, connect the charger, and try to power on the laptop.
If it didn't work, you need to visit the technician
If it worked, disconnect the charger and connect the battery
If it worked, things are going well.
If not, the battery have problem.
Please tell us the results
Regards
Nov 21, 2011 | Computers & Internet
Powercord replacement
please explain further.. do you mean your laptops power adapter cord?
thanks for using fixya
Nov 10, 2011 | IBM ThinkPad 380ED
My new behringer vmx 200 dj mixer dosnt play sound from ch1 ...ch2 works fine ive tried everything but ch1 dont work
be sure when you select the chennel 1 input as your audio source you have an audio device plug inn at the channel 1 audio input..
Sep 11, 2011 | Audio Players & Recorders
I need to buy a adaptor/charger that will work for my laptop. The model # is dv7-1247cl laptop. Thank you Randall Miles rmiles04@charter.net
here the specs for your charger: 65Watts/input:100-240 volts 1.6amperes/output:18.5 volts just make sure the pin will fit the laptops female socket.
Jul 12, 2011 | HQRP 90W Laptop AC Adapter / Charger...
My Dell Laptop was working fine in 220V country, when i moved and try to use it in US (110V) the charger LED is ON but once i plug it in the laptop it goes off and the laptop is not working. i even tried...
So two different devices, each with their own charger, don't work in different power outlets in different rooms? How about if you plug a light into the same outlet. Does the light work? Does it dim when you plug the charger into the laptop? If so you have a bad electrical system, either a loose wire or bad outlet.
Jul 15, 2017 | Dell XPS M1330 Notebook
HOW DO I RECHARGE SPECIFICE CHARGER OR BY COMPUTER
By computer so that you will obtain the specific charger that you need.
plankw,
What laptop is it? Manufacturer name, and Model Number.
(Bottom of laptop)
Also,.....on the Bottom of the laptop is stated the Input, and Output voltage.
Your concern is the input Voltage, not so much about the Amperage.
(V = Voltage, A = Amperage)
Example;
Input: 12V2A (Sometimes printed as 12V~2A)
12 Volts at 2 Amperes.
The AC adapter (Charger) must also have the correct plug to fit the laptop's DC Power Jack.
(DC IN)
Regards,
joecoolvette
Apr 21, 2011 | Computers & Internet
Tom Tom GO720 wont recharge with car charger inn car, but does charge on USB
either your car charger cord has a short or break in it, or your charge port (lighter socket) dont work. check your fuses to see if it aint something there, then try to find another cord. It wont be a prob with your TT as it is still able to charge from usb. The problem has to be on the car or car charger (still should be an easy fix)
Aug 03, 2010 | GPS
HP 6530b Notebook Logo
83 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
