Question about Sharp Televison & Video
Scematic for runtka396wjn1 - Sharp Televison & Video
Front window switch came apart
that really sucks the clips that hold the pins on the wires are probably brocken if thats the case you can get a pig tai or even a new conector from the diealer or junk yard youl need the wireing scematics to replace the pins in the proper order most chevys have similar conectors with diferent wireing colors if you get it at the junk yard you can get the scematics for that rig and match them with yours hop this helped
Jul 22, 2012 | 1995 Chevrolet G20
Where is the best place to purchase the circuit board Runtka396wjn1
We often use www.shopjimmy.com for LCD parts. They are used parts, but are quite often the ONLY way to obtain a replacement (especially for less than the cost of a new TV).
Jul 11, 2011 | Sharp LC32D44EBK 32 in. LCD TV
My masher wont stop filling with water or agitate
if water stops coming into machine when you pull the plug you have faulty water level control or the hose going to it.
check the hose for cracks or worn spots, repair or replace.
If the hose is ok you have a faulty control.
If water does not stop when you pull the plug you have a faulty water valve.
You can try dismanling it and cleaning or simply replace it.
Jul 03, 2009 | Whirlpool LSR5132PQ Top Load Washer
Scematic
Hi there!!
If you have an echo board what kind is it? I can give you the connections and where they go it just depends on which echo board you have!! I can also tell you where that talkback goes!! Let me know
Dennis
Dec 10, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Scematic ????
will I find the manual no. and go to the library and usually they can get it for me within 2 weeks.
Oct 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Televison & Video Logo
846 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
