Question about ACER Labs ALi PCI to USB Open Host Controller
I need the drivers ALI PCI to usb host controller...
    Master:
  • 473 Answers
Go on Google then Type Exemple.... Download Acer Labs ALI PCI to USB Open Host Controller...
Posted on Oct 09, 2010
Drivers for hd1600s
if you are referring to usb drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question/exclamation mark ? ! or a red X you will need to update the driver
right click to reinstall drivers
if you can see your usb drive but its not working
if your computer came with a motherboard disk the drivers could be on it
ports(com&lpt)right click update driver
or you could download them
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don't use numbers and / - you might have to try a few times to get it right
also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Oct 01, 2011 | HP HD1600s 160 GB USB 2.0 Hard Drive
Asking for driver
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
hope this helps you
Sep 27, 2011 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
I am using a fujitsu mpg3307ah in an external usb mode and need to install the correct driver in my vista laptop.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Sep 26, 2011 | Fujitsu (MPG3307AH) 30.7 GB Hard Drive
Cant find driver for SimpleTech 250gb external hd. Is it available?
Should not be necessary. It is recognized by the system automatically. Try connecting to another port, check the data cable and the connection to the unit, it may be corroded or loose.
Sep 13, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
I an not have driver usb for hdd2193 for fix problem
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
if you dont have a motherboard disk you will need to download the drivers
hope this helps you
Sep 11, 2011 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Hi, i do have a n1996, ms-6547, motherboard, imtrying to download a fix for and also for usb 2 and i can not find them,thanks in advance
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
If your Device Manager shows an ENHANCED USB Host Controller, the system has High Speed USB (USB 2.0) capability.
Types of High Speed USB (USB 2.0) Host Controllers
· Intel Enhanced
· SiS Enhanced
· VIA Enhanced
· ALi Enhanced
· Standard Enhanced
· NEC Enhanced
The system shown has onboard Intel High Speed USB (USB 2.0) with an NEC High Speed USB (USB 2.0) PCI card installed.
The key word is ENHANCED. If you have an ENHANCED USB Host Controller then you have High Speed USB (USB 2.0)
All other types are USB v.1.1
hope this helps
Nov 11, 2010 | MSI MS-6547 Motherboard
I dont have 2.0 usb how can i update my present usb controller
Dear Friend,
You can identify whether your PC has Hi-Speed USB or not relatively
easy. Open Device Manager and expand the Universal Serial Bus section. There should be an "Enhanced" USB host controller present.
There are currently 7 manufacturers of the Hi-Speed USB host silicon themselves:ALi (Acer Labs), Intel, NEC, Sis, VIA, NVIDIA (shows as "Standard" controller),Philips.
Note:Older computers may have only the slower USB 1.1 interface. Adding USB 2.0 isn't difficult, but it does require a hardware addition.
There is no need to Update your USB in Latest PC.
You have to do one thing is that ensure you are perfectly Installed your Drivers(Included in CD which you Owned when Purchasing PC).
I hope You made it clear ...Thanks for Contacting FixYa...
May 04, 2010 | IBM NetVista PC Desktop
DRIVER PROBLEMS
you have to install the chipset driver using your driver cd...
is this cleared your problem?
Feb 19, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
I NEED A DRIVER PCI to USB ENHANCED HOST CONTROLLER
sounds like an add-on USB card
lots of drivers at : http://drivers.myfreewares.com
If you can read the manufacturer from the card that would help narrow it down.
Or...check the large chip (integrated circuit) for a manufacturer logo or name, NEC is a typical chipset maker and there is only a small handful of different chipsets but many makers of the cards.
Oct 25, 2008 | Computers & Internet
Can't connect psp component cables to tv
okay. here's what you need to remember as i encountered the same issue and had it resolved.
1. connect the psp tv out component cable to the tv. make sure you have every cable in their correct plug-ins.
2. on your tv remote, press output until your tv displays the correct output data info. it will display component 1 or component 2. make sure this aligned with where you connected your component cable.
3. turn on the on the psp, then press and hold the display button ( it is near the start and select buttons on your psp, with a box like icon. after 5 seconds, it will give you a gray screen with a box icon and an arrow which means you are transferring the data out from the psp to your tv display.
4. enjoy your psp on tv!
Aug 08, 2008 | Video Game Consoles & Games
Computers & Internet Logo
173 people viewed this question
Top ACER Labs Computers & Internet Experts
David Payne
David Payne
Are you an ACER Labs Computer and Internet Expert? Answer questions, earn points and help others
