Question about Kenmore Refrigerators
I have a Kenmore refrigerator side-by-side model 25351399104 that makes a constant clicking noise every 13 seconds. I also believe the fan has not shut off in weeks. It is cooling just fine and no ice buildup. It is coming from the top in between the freezer and main part. (I already shutoff the ice maker and took that out of the equation.)
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
the dr
  • 447 Answers
SOURCE: How to install a frigidare ice maker IM115.
the wires should be behind a cap that covers the hole for the water tube on the pack panel in the freezer.
Posted on Nov 19, 2007
Oceti
  • 51 Answers
SOURCE: Frigidaire model # FRS26ZNHB2 side by side not cooling
T
From your description, you have a bad evaporator fan motor. The part number for a replacement motor is #5304445861.This is not a direct replacement but is more reliable.Remove everything in the freezer, take off the back panels and you will see the fan.
If there is a large frost buildup on the coils and the fan is turning you have a defrost problem. If that is the case, please call me at 334-347-0000 and I will walk you through it.
Posted on Jan 14, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 1122 Answers
SOURCE: Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Posted on Jun 17, 2008
I have a Kenmore Bottom freezer side by side model 795-7130. The evaporator fan is making noise that stops when I open the door. How do I access that fan please? I can't find a repair manual fo
it is inside the freezer, remove the drawer, then the rails that hold the drawer. this can be an intimidating job. then the fan cover at the top of evap cover needs to come off. then you can remove the evaporator cover which may have screws or may just pull off. if it gets too big call for service
Jan 08, 2012 | Kenmore Refrigerators
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Showcase freezer fan motor makes constant clicking noise
Is the noise clicking consistantly?or just on again off again?Yes there may be a faulty motor.Try removing the wires and tape them up then run the unit if there is still noise need more info .And to let you know yes they can be made into a low quality air compressor:) hope i helped :)
May 11, 2009 | Frigidaire FRS26R4A Side by Side...
My GE profile refrigerator makes a fan noise
Hello my name is Tim Ehrhart, it sounds like you may have a wire that is hitting the fan blade wich can be seriouse as if it shorts out it could catch fire. A trick to fix this is to take off the cover and make sure the fan is clear or all wires and everything else, if there are wires either tape them back, hot glue them or redirect them away from the fan. I hope this helps you out.
Mar 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer not working
sounds like the clicking noise could be the overload on the compressor. pull off grill cover on bottom front of refrigerator check to see if condenser coil if blocked with lint and dust if it is clean it throughly it could cause the compressor to overheat and cause the refrigerator to thaw and the overlaod to make a clicking noise. hope this helps you out
Dec 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Elite Trio = clicking and fan running constantly
Sounds like a problem with the compressor.  Get a service tech in.
Nov 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Kenmore model 59502990 25 qf side by side refrigerator
hi thanks for the question yes there is order a relay by model # and install it should be ok thanks the appliance doc
Sep 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator making a whinning noise.
sutty, you have a 2 speed DC evaporator motor in this model. There should be at least 60 seconds between any fan speed changes. On the back side of the refrigerator you have a main board. Unplug J2 connector on the board. Check for 13VDC between pins j2-3 and j2-8, then check for 8 to 13VDC between j2-3 and j2-4. If the voltage is correct I would suspect the evaporator motor. If the voltage is incorrect, then the problem is in the main board. Pins read from left to right 1 through 8. Catriver.
Jun 29, 2007 | Hotpoint (HSM25IFTSA) Side by Side...
Refrigerators Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
