Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
Our new 48" Viking side by side does not feed ice cubes adequately. If you need several glasses of cubes it stops feeding and when one opens the freezer door they are piled up and fall all over the floor. Not what I had expected from a new refrigerator/freezer from Viking.
  • 3 Answers
I experienced the same problem several times with our VCSB483DSS also.
What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.
I think the the problems are:
1 - over application of foam insulation in the chute pathway in the door.
2 - possible bad timing on the flap opening causing the falling ice to get stuck.
My solution for the past 6 years:
1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.
2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.
Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
Posted on Feb 28, 2013
2 Suggested Answers
SOURCE: 48 " viking ice maker tray frozen no ice
Try replacing
the icemaker unit. I used Supco model RIM943 and its working great. Found it online for $55 on line.
My Viking 48" ice maker has given me a little trouble too. The first ice maker assmble was replaced under warranty. It only came with a one year warranty so when it just went out again I thought I would take a look. Just like you I had no ice. It only take two screws to remove the ice making unit and a quick discount plug. I read up on the unit to trouble shoot it. My Ice maker had the ejection forks stuck in the down (in the ice cubes) postion indicating the unit was out of sync and needed to be completly replaced.
On another note:
I also had a proble with the flapper ice cube door on the outside ice dispenser. Ice cubes would get stuck in the door and would not drop into the cups. This was a lot tougher to fix, but I like figuring things out. Turns out I had some ice that got stuck in the flapper and some how it melted and froze back up to lock the flapper. When the motor came on it sheard a shear pin in a coupling just off the drive motor. I made a home made shear pin and put it back together and all work great now. It was a bit of work to take it all apart and to tell that the motor was good and the relay was working right.
Posted on Dec 13, 2009
Ice cube tray does not fill up water feeding tube is frozen.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valve and this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
May 24, 2012 | LG LSC27910 (265 cu ft) Side by Side...
Ice maker is not working. it turn and make the turning but no ice is producing.
Hello. Check to see if any water is entering the ice cube mold. Most likely it is not and the cause is either a clogged filter, a clogged supply line, a kink in the 1/4 inch line that feeds the fridge, or a frozen valve that would normally open and close to let water into the ice maker. J.
Aug 07, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice maker is not getting water to make cubes.
The red light should flash, the most likely suspect is that the inlet tube that carries the water to the ice maker is frozen. If you open the freezer door and hold the swinging door in front of the ice maker up you will see a black rubber tube coming down from the top. If it feels hard it may have an ice block in it.
The best way to clear the block is to turn off the refrigerator or unplug it, warm up the tube with a hair dryer or for quicker unthawing take a turkey baster and squirt hot water into the tube catching the run off with a towel.
It can take quite some time and several cups of hot water to finally clear the ice. Once done it will take about 2 hours for the ice maker to cool back down and start a cycle to test it.
Apr 18, 2010 | Whirlpool GD5SHAX Side by Side...
Viking side by side makes very little ice
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Apr 09, 2010 | Viking VCSB423 Side by Side Refrigerator
I have the Scandia probably 5 yrs old...feed dog is up but wimpy...not moving fabric....it's sporatic...many times the fabric stops and the needle sews in place and then is will move a little - stitch...
The feed dog motor needs re-calibrating. If recalibrating does not resolve the problem, the feed dog stepper motor may need to be replaced. These tasks have to be done by a certified Husqvarna Viking service technician. Suggest that you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jan 08, 2010 | Husqvarna Viking 1
We have a jenn-air jfc2087hrs (french door model) and the water pressure from the internal water dispenser is very low. the line has plenty of pressure.
If your ice maker is making full size cubes then it should one of 2 problems.
The water valve on the bottom back of the machine is a dual valve. One side feeds the ice maker, the other side feeds the water supply.
1. The dual water valve. is going bad. The water side is malfunctioning.
The dual valve must be replaced.
2. Your model should have filters for the water dispenser, and need replaced.
Try changing the filters first.
Oct 04, 2009 | Jenn-Air JFC2087HRS Side by Side...
Ice is forming around the auger under the ice bin. constantly have water dripping from ice cube shoot
the door that the ice comes down to fill glass is not closing; the ice chute door just above the lever to fiil glass with ice it is either jamed with ice or is broken and needs a new repair kit.you can inspect by opening door and look at approx. 3 inch door that ice falls threw to see if closed.warm air causes ice to form.
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Try replacing
On another note:
Jul 27, 2009 | Viking VCSB423 Side by Side Refrigerator
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
GE Side by Side: Ice Maker Issue
Is the freezer working at the correct temp ?? Is the ice maker feed pipe blocked ??
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
309 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Audie Bogus
Audie Bogus
Level 1 Expert
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
