Question about Plumbing
One pipe can fill a tank in 4 hours. Together with a second pipe, the tank can be filled in 3 hours. How long would it take the second pipe alone to fill the tank?
    Problem Solver:
  • 8 Answers
12 hours
Posted on Oct 22, 2010
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
I have a Toyota Corolla NZE 2001 and I have trouble filling my tank. It fills for 3 or 4 seconds at a time before clicking off and I have to change the angle of the nozzle several times, pull it further...
Do you have an engine light on? Sounds like the tank isnt venting properly, if you can peak under the car near the gas filler neck, check for a small pipe/hose going to the top of the neck, check for corrosion or anything odd and start with that.
Dec 23, 2017 | 2006 Hyundai Sonata
2010 ford mondeo diesel wont start after changing fuel filter, please help!
on a ford mondeo 08 the fuel filter is at the rear of car u take old filter put in new one fill with fuel put back together then put a pipe on feed [there might be a bleed niple on top that will be easier] suck till fuel comes out conect pipe back turn ignition on for 15 seconds 3 times to clear air then start done
May 20, 2012 | Cars & Trucks
Fill tank for old VPR
how do you clean a VP 17 tank, the sprayer gets filled with scale, which must be coming from the tank I used the spring cleaning tool so mani times .
Asbjoern
May 04, 2012 | Bunn VPR Coffee Maker
My Campbell Hausfeld compressor is brand new and runs and runs without building up pressure.
It sounds like you have a leak , you need to find where it's leaking.
But first things first - you said it's brand new , I am assuming you filled the pump with the proper amount of oil before running it.
Second thing is for the first run per the book you are to open the drain plug (bottom of tank) and run it for one hour. This is to break in your pumps rings under a no load condition.
I would then let it cool off for an hour or so , re-check the oil level , close the drain and let it pump up to fill the tank. If it is not building pressure check the drain plug , the unloader valve, fill pipe (the pipe from pump to tank) and fittings for leaks.
I am sure you have placed a female quick connect on the regulator so be sure it is not leaking also.
Good luck !
Don F
Sep 08, 2011 | Campbell Hausfeld NoEX8008 5HP 26GAL...
1994, 6.5 LTR DIESEL SIERRA. RUNS FOR ABOUT 1 MIN THEN CUTS OUT
Check that the fuel tank breather pipe is clean and not blocked.
Sep 01, 2009 | 1997 GMC Sierra
With tank empty I can't use the full pump pressure of the gas pump. Nossle stop like tank is full enen when I first start to fill the tank.
check for clogged fuel vent on fiel tank, it has a charcoal cannister that is vent for the tank, probably clogged... please rate my help, thanks...
Aug 05, 2009 | Hyundai Motor 2002 Sonata
Suzuki Bandit 600 GSF 2003 Fuel Overflow
Suzuki say not to fill the fuel tank to the top. fill it 3/4 full to allow for heat expansion.
May 31, 2009 | 2003 Suzuki GSF 600 S Bandit
I can't fill the tank. The nozzle keeps clicking off.
the fill vent is inside the fill tube . your fill is 2 inch and inside it is a 3/4 inch that your gas goes down it runs from the filler neck to the 3/4 mark inside the tank your vent is the area between the outside if the inside tube and the inside of the outside tube . and vents through the gas pump nozzle ... gm has a problem with there trucks where the inside fill tube gets kinked after a while and kicks off the pump . i have never seen anyone fix this problem and have it work for long . i have a 2003 chevy truck same problem have to fill real slow . pulled tank , checked all lines changed fill neck ( flapper door in fill neck bad ) .... put it back . same problem . good luck . i gave up
Mar 13, 2009 | 1984 Chevrolet S-10
"water pipe empty" icon will not disappear from display screen 3, cannot brew coffee, first use - second machine to have this problem
I have a Siemens surpresso S40 with the same problem.
Try to fill the tank with hot water. I dont't know why but it solved the problem for me.
Jul 11, 2007 | Bosch Benvenuto B20 Espresso & Coffee...
Plumbing Logo
74 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
