Question about Microwave Ovens
I am looking for an instruction manual for the sonic blade knife
How do I cook a frozen 2 lb meat lasagna in my Jetstream oven?
I would start with a slow 250 oven for about 45 minutes. If the lasagna is thawed by then kick the oven up to 350 for another 30 to 45 minutes. Test temperature with a thermometer or knife blade to see if done.
Sep 08, 2017 | Nesco American Harvest Jet Stream Oven
Replacing a handle on a kitchenaide microwave
Hello
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Microwave Ovens
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
Problem with the GE JVM1350BW/WW/AW/SY Microwave Oven The handle broke off completely. Can it be replaced? Doesn't look like there is way to get back of door off to replace/repair handle.
The inner plastic ring has to be removed. That WIDE ring is called the choke. Use a flat bladed screwdriver and a knife blade to get it free. It has tabs on the inner side and the outside that have to be unlatched. Once the choke ring is free you will have access to the screws.
See this video:
Sep 24, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
I've got a broken Breville Ikon 550 blender. It smokes with in seconds of turning on, looks like the blade assy is broken as its little bit wobbly & gives resistance when turning. How & where can...
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 19, 2011 | Microwave Ovens
How do i replace door handle
Open the door and look at the inner door. You'll see a frame about an inch and a half to two inches wide surrounding the window. You'll need a very flexible putty knife of about the same width. The narrow frame around the window is metal. Don't scratch it! Put your blade into the gap just above the window part and slide it (no scratching) along until it hits something. That's probably one of the little "L" shaped hooks holding the frame on. Back the putty knife out a little a GENTLY pry downwards. You should see it pop loose at that point. It will try to pop back into place, that's where a second putty knife or something similar is handy. Once you get a couple of those loose it goes pretty fast. Just keep prying and peeling until it comes off. GENTLY. And, no scratches. Now you can see the two screws holding the handle. Once the handle is replaced, that frame will snap back into place just by pressing on it. That frame cost is about $40.00, so don't get in a hurry.
Good luck.
fil
Mar 02, 2011 | Frigidaire FMV156DC Microwave Oven
No problem, except we need a manual for our Remington Bread Maker BM-50
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Jan 11, 2011 | Microwave Ovens
Farberware v-blade mandoline slicer instructions - nothng in or on box - how do I use and put together
I bought a faberware V-blade Mandoline slicer and I would like to have an instruction manual for the blade usage please
Jun 21, 2010 | Microwave Ovens
Our door wont shut...
cheap and effective way to fix is to gently remove the plastic ring from the inner door with a butter knife or small blade screw diver and attch the door hook spring to the inside metal fins
Feb 04, 2010 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
122 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
