Question about Cannon Canon i960 Photo Printer
Ip1000 i dismantled my canon pixma ip1000 printer... i am puzzled how to reinstall the two springs under the cleaning pad.. do you u have any pictures on that how it was assembled?
I want ip 1000 pixma driver for setting of printer
Posted on Nov 21, 2008
Cvgc
Posted on Aug 20, 2008
Pixma 150 waste
hi
you need to buy the waste toner container (its inexpnsive, plastci container that holds waste toner
go to this site first and follow instructions on HOW TO CLEAN THE INK ABSORBER
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Feb 04, 2012 | Canon PIXMA iP1000
Wast ink absurber full..error27
Hi
The wast ink absorber full, if you want to clean the ink absorber at home without wast money, i will provide you the example in Canon printer,how clean you ink absorber follow the mention below instruction and remove the error of ink absorber.
God Luck
Sep 05, 2011 | Canon PIXMA iP1000
How to remove the ink waste remover for canon ip1000
Hi
Please follow the mention below instruction.
1 Open your printer 2 To protect hands from Ink wear thin latex (or similar) gloves 3 Locate the Waste Ink Pads on the inside of your printer. They are on the right hand side
and are quite small.
4 You can remove the pads and the holder with a gentle pull.
5 Using a tissue, soak up as much ink as possible and clean the area around the waste
ink area.
6 There is one more waste holder in the right back bottom of the printer. A kind of
sponge. There are few screws and plastic parts to be removed and this sponge needs to be
washed, dried and placed again. Be careful and patient. This is no understatement. On the
iP1500 this requires the dismantling of most of the printer. Take a photograph (even with your
cell phone) so you can trace back your steps. On the iP1500 the drive motor on the side (Just
behind the waste ink pads) has to be removed to get to the main sponge. You also need to
take care as you lift the slide/carriage. Below this you find 5 little springs.
7 Carefully replace the holder and the pads. Close printer.
8 Whilst printer is disconnected from the mains power, press and hold the power button
and reconnect to ac power.
9 Release the power button.
10 Press the power button again.
Thank
Aug 22, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
Waste ink absorber is full. what should i do? so i can use back my printer
Siijakiah, I have successfully taken apart and cleaned the waste ink absorber. My problem came when I was putting it back together. Can't find where the two springs under the ink cartridge rest go.
There are two small hard pads on the right hand side under the ink cartridge rest that are fairly easy to clean (just press gently with a tissue until no more ink comes out) as long as you don't drop them.
There are also two large pads right at the bottom of the printer that need cleaning and this requires that you take your printer apart. I can describe how to take it apart and clean them. I can also describe how to get it nearly back together.
If there is anyone else out there who is kind enough to explain/describe where the springs go, I am sure I would not be the only grateful person.
Aug 18, 2010 | Canon PIXMA iP1000
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Canon Pixma ip1000 dismantle
Hi there you can try
Temporary Fix
This always works in case you need your printer for Emergency ^_^.
  1. Turn off the printer
  2. And unplug the printer power cable
  3. Press and Hold the POWER button
  4. Plug the power cable again
  5. The indicator (LED) should be green
  6. Press and Release the RESUME button, the indicator (L.E.D.) should be orange
  7. Press and Release the RESUME button again, the indicator (L.E.D.) should be green
  8. Release POWER button
  9. Windows will detect new printer and you just have to install it again.
  10. It will create a copy of Canon i320 printer. Just delete the old one and rename the copy.
  11. You are done.
Jul 09, 2009 | Cannon Canon i960 Photo Printer
Can't reassemble back the the waste ink pads with the 2 springs
I have the same problem. did you ever find a diagram to help put the springs back in?
Feb 21, 2009 | Cannon Canon i960 Photo Printer
Canaon pixma ip1000
i need driver for pixma ip1000
Sep 22, 2007 | Office Equipment & Supplies
Depress power button while plugging the canon pixma ip1000. When you depress the power button, the printer can be used even if the in waste absorber hasn't been replaced.
Apr 15, 2007 | Cannon Canon i960 Photo Printer
Cannon Canon i960 Photo Printer Logo
239 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
