Question about QMark MUH-35 Heater
When garage was finished electricians put in a 4 wire rec in the wall. when I wired up the plug that goes into the rec I used all wires and when I wired the heater I just capped the red wire. Problem is I don't think the heater is putting out near enough heat.
3 Suggested Answers
appman67
  • 33 Answers
SOURCE: Problem wiring 240amp baseboard heaters
12 gauge wire sounds under sized for the application. And 20 amp 240 v breakers might be sufficient if you where wiring the heaters separately. But be sure that your wiring is not romex - because romex is an insulator and is not permitted in conduit. I would suggest that you up size your wire to 10 guage and your breaker to 30 amp as well. Then double check your heater wiring connections to insure that they're wired the same throughout.
Posted on May 03, 2009
panilling9
  • 284 Answers
SOURCE: I am trying to replace a electric baseboard heater
if you have a electric meter check the voltage coming out of the wall to be sure it is 220 v???? (meter across black and white)then with your meter only test black wire to ground and white wire to ground seperately you should have 110 from each wire to ground?
If you have only 110 to the black and no reading on the white, you either have a bad breaker or a 110v circuit
If you read 220v and you new heater is rated for 220v black to black and red to white wall thermostat or built in as long as you have 220v to your connection from the wall or your wall thermostat when turned higher than room temp.
Bare grounds tie together and mount to your green ground screw
Posted on Sep 25, 2009
Why does my 3.0KVA transformer keeping tripping my garage electrics but works ok when I plug it into the socket in the kitchen
the wiring on the transformers plug or the wall socket in the garage might be wired wrong. black is hot white is not, 110 v plug
USE a to touch power test light or a voltmeter and compare power from kitchen and garage outlets the plugs wide blade/prong should show no light or voltage when checked to the gound, if it does the wall plug is wired wrong.
hope this helps vote up 4 the=
Jay the pool pump motor repair guy Longwood FL
Jul 01, 2017 | Kitchen Ranges
Install grounded wall outlet
Hi there! First, that is a really good extension cord you have and it already has the grounding prong (the rounded thing). All you need is an outlet that can accept a 3-pronged plug. But, then you knew that didn't you? OK - Here are several ways to solve the problem; 1. - easy, safe and ok without changing the outlet - buy an adapter plug that can accept 3-prongs on the female side (with the holes) and has 2 prongs on the other side or male side (with things sticking out) (BTY-i did not make up theses gender-biased terms and I think they are politically unsensitive but that ss what they are called)
Solution 2 - harder and costs a bit more if you do it yourself OR could be expensive if you hire an electrician. ALWAYS hire the electrician to be safe, within local code laws and if you are not big-time handy like me (short for poor but learned a lot by reading codes and restoring 7 old houses with ALL older, non-grounded outlets!)
OK - here's how you "Do-it-Yourself" - step by step (gee. maybe there is a video on youtube for this or should be or I will make one...)
1. SHUT OFF THE ELECTRICITY TO THE WHOLE HOUSE or
find the circuit for the outlet you are changing and flip the circuit breaker switch in the electrical panel in the garage or basement - use a helper to find it by having them plug in a light to the outlet while you flip the circuit breaker switch. When the light goes out, mark or label the circuit breaker to find it next time!. When you are sure the power is off,
2. unscrew the wall cover (one small screw),
3. look at the box holding the old outlet, it is probably metal, see how it is attached to the wall, remove the screws or nails holding it in place, NOTE: if this looks scary or is full of many wires, dust, spiders, and confusing stuff - STOP AND CALL AN ELECTRICIAN
if it looks like you can handle it, use a pair of long-nosed pliers and pull the old outlet (not the metal box) out of the box, along with all wires going into it, (there may be up to four wires going to this outlet:
a. - 2 wires; one positive, black wire ad one negative, white wire, there MAY be a third, bare wire that someone cut off or it may only be the 2 wires,
b. - 4 wires; 2 like above going IN to the box and 2 going out to another outlet somewhere down the line,
4. Unscrew and detach all wires and label them to remember where they came from (brass screws are positive and white ones are negative),
5. Put the old outlet aside to throw away later (in case you chicken out or freak out and decide that this is a bad idea or not as much fun as you thought it would be :) )
6. Now, pick up the new outlet you just bought at Home Depot and you will see it looks like this:
Face of Outlet --------------Neg & Ground side---------Positive side
install-grounded-wall-outlet-f2or3qxpqjy5fad3fzjv4tgc-2-0.jpg install-grounded-wall-outlet-f2or3qxpqjy5fad3fzjv4tgc-2-2.jpg install-grounded-wall-outlet-f2or3qxpqjy5fad3fzjv4tgc-2-0_0.jpg
Image 1----------------------------Image 2 --------------------Image 3
See the small lower screw on Image 2? THAT is where the ground wire goes and it is the bare wire I talked about earlier. Maybe we should talk a little about electrical wire here if you are still with me:
New wire for homes comes in many sizes with weird numbers but don't worry, all you need to know is two sizes; 12 and 14 - 12 wire is for 15 or 20 amp circuits and 14 wire is for 15 amp circuits. Size 14 wire is easier to handle but should only be used for lighting and small appliances or TVs and radios. Size 12 wire is the best one to use for everything because you do not have to worry about the things you plug in....(I wonder who sits around, staring at their outlets and worrying about them...? not me, I use 12 for everything)
Back to the wire! - You need 12-2 WG wire, it should be labeled like this:
see the numbers 12/2 and letter W/G ? that's what you want to see OR use if you have to use new wire. OK time for a break here and a special note - DO NOT TRY TO CHANGE THE WIRES IN THE WALL. GET AN ELECTRICIAN!
If you are still reading this far you have too much time on your hands, are bored, or just bought an old house and can not afford an electrician OR resent how much they charge by the hour.
7. Attach the existing wires to the NEW outlet like this:
a. - Black wire to a brass colored screw - Image 3 above b.- White wire to a white screw - Image 2 above c.- Bare wire to the lowest or GREEN screw - Image 2 above
(this is if you have one big wire going to the outlet, meaning this id the end of the line or run or last outlet in the room...IF you have TWO big wires going in and then out of the outlet, do this:
d. - INCOMING black wire to TOP brass screw,
e.- OUTGOING black wire to LOWER brass screw,
f.- INCOMING white wire to TOP white screw
g.- OUTGOING white wire to BOTTOM white screw
f. - BOTH bare wires, in and out, to the lowest or GREEN screw
( note - this is a big pain because the wire is stiff and it is hard to attach all THREE bare wires to the green or ground screw - YES, I said THREE bare wires - Another wire has to go from the green screw to the metal box to ensure a proper ground)
At this point you are almost done! - However, now you have to:
8. stuff all these wires BACK into that little, teeny metal box along with the new outlet and make sure that none of the screws or wires, except the bare ones, touch the inside of the metal box...
9. Replace the outlet cover and bingo, you are done.
10. Turn on the power again an check the outlet for proper grounding. WHAT? How do I do that you ask? Go buy this thing:
Stick it in your new outlet, cross your fingers and hope you get TWO green lights! You win! If any other combination of lights or no lights show up...CALL THE ELECTRICIAN !
good luck from: Tom Crowley, Man of Action!
Mar 17, 2014 | General Electric 50670 3-outlet Grounded...
Three prong to 4 prong outlet
Yes it can be. I suggest you get a licensed electrician to handle it.
Jan 27, 2013 | Bosch Nexxt 500 Dryer
How do I wire a GFCI socket with a wall box that has 4 wires running into it? 1x green ground wire, 2 x hot wires and 1x wire that that electrician put white tape around. The electrician knew it was for...
If you have two hot wires you maybe set up for 220vac. If this is a 110vac circuit you have a hot in & hot out . Did the electrician run a designated circuit for the spa? GFCI comes with instructions. Find the breaker and check the voltage. You don't want to burn up the spa.
Apr 16, 2012 | Pool & Spa
During a garage remodel, my Sears automatic garage motor was unplugged and the wire going from the motor to the push button on the wall had to be cut and spliced back together. Door wouldn't go down on...
Make sure the solid white wire from each door sensor is attached to terminal #2 and the white wire with the black tracer is attached to terminal #3.
The solid white wire from the wall control goes to terminal #2 and the white wire with the red tracer goes to terminal #1.
If the green light in the wall control is blinking press and hold the lock button for 3 seconds.
Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Providing modem output to house addition
Looking at the image in the link below, your computer only uses the orange pair and the green pair. You could break out the blue pair and brown pair and actually run 2 separate phone lines through this cat5e cable also. For reference this image is shown with the end of the plug facing you. The only issue I see with this is to make sure you know which 4 wires you are using in the 12 wire cable and connect the orange pair and green pair to the same wires on both ends. (Do the same with the blue pair and brown pair for your phone line.) If you need any further assistance please feel free to contact me.
http://www.beginnercode.com/wp-content/imgupload/cat5e_T568B_Wiring_Diagram.gif
Oct 30, 2009 | Computers & Internet
Drive Motor Will Not Operate
It sounds like the wiring to the wall control is shorting or the wall control itself is bad. You can do a process of elimination by first removing the wires from the back of the wall control to eliminate it and then by removing the wire from terminal 1 on the rear of the motor unit to eliminate the wiring. Make sure you remember which wire goes where on the wall control. They are color coded.
May 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster pro garage door opener opens randomly
CHECK FOR REMOTE CONTROL DAMAGED OR WALL CONTROL SHORTED WIRE
Apr 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wiring diagram for garage door opener
Can you hook up sensors to an older craftsman garage door that never had them?
Jun 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Telephone wall jack
Did the old wall jack work before you removed it?
Are the wires still connected or do you remember where the wires used to go.
If so, then what I would do, is with a phone connected, start disconnecting 1 wire at a time. When the line goes dead, then you know that is one of the wires that you need to use. Reconnect that wire, and mark it, and Keep doing this until you find the other wire that makes the line go dead.
Then you will know which 2 wires you will need to get the jack working.
Usually, the standard color wires that you need for the new jack is Red and Green for a single line phone jack.
Hope this helps.
Good luck.
Mac
Feb 21, 2008 | Lands Phones
QMark MUH-35 Heater Logo
20 people viewed this question
Top QMark Heating & Cooling Experts
Paul Carew
appman67
appman67
john h
Are you a QMark Heating and Cooling Expert? Answer questions, earn points and help others
