every computer has an ip adress you might have to go to your internet setting and find some thing that says some thing like... internet adress hook up hopefully you keep files on your computer becuase with out your ip adress you might not be able to hook up its sorta like a combination hope it helpes:)
Make sure that your router isnt blocking your xbox from grabbing a static ip adress. It it is doing the same thing, try plugging the modem directly to your xbox 360 to see if it isnt your xbox.
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can
connect all your devices by ethernet cable to the internet then it's
set. If you are using a wireless connection and if it asks for the WEP or
WPA key, make sure that you are entering the correct encryption key.
You may want to call your router manufacturer to know the correct key
for the wireless connection. FYI, it will say that the wireless network
is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I
suggest you to call your Internet Service Provider to check for the
Internet connection and obtain these (static IP address, subnet mask,
default gateway, primary DNS server and secondary DNS server). If your
Internet is okay, enter the IP settings manually on the console (System
> Network Settings > Edit Settings > IP settings).
For some reason everyone has the same problem buy the Xbox 360 wireless kit and should work but for now you might as well just wait untill get its fixed
