My denon avr-1906 amp will not turn on correctly. When the standby button is pressed the indication surrounding the button flashes green but when you hear the relay click in for presumably the power amp, it powers down and the indication returns to red surrounding the standby button. The manuals hints and tips say that the vents could be blocked or its over heating, the vents are clean and the unit is cold so I'm at a loss as to what to do next?
  • 4,234 Answers
The amp is shutting down to prevent further damage. This is what is sometimes referred to as protect mode. There is a problem with the final stage of the amplifier. The most common parts that fail are the output transistors. Figure on $15-$40 in parts plus the local labor rate for the total repair cost.
Dan
Posted on May 30, 2008
How do i get it out of standby
your amp needs servicing there,s a problem only for qualified technician
Sep 16, 2015 | Denon Avr-2000 A/v Surround Receiver...
Reset factory settings of my Denon avr 2800
From Denon support:
To reboot, turn receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory default.
Sep 08, 2013 | Denon AVR-2800 Receiver
DENON AVR 1507 short?
unplug it, let it set for about 15 min., plug it back in and see what happens. Hopefully it will recycle itself. If that fails, with your theater remote, you can pull up it's functions screen on your TV, and probably return it to factory default settings. That would be a last resort for me before seeking professional help. Good luck. . .
Jul 27, 2017 | Denon AVR-1507 Receiver
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
Denon 1906 all the right channels speakers not working
when turn on the amp,the volumn cannot under control
Oct 10, 2009 | Denon AVR-1906 Receiver
Standby light stays red and will not turn unit on.
Try to reset the macroprocessor. Unplug the unit from AC, hold both buttons SPEAKER A and SPEAKER B and plug the cord in outlet. After display flashes several times release the buttons. No result? - repair shop.
Apr 05, 2009 | Denon AVR-1906 Receiver
Speakers on the right side of my AVR will produce no sound in any
change the right channel audio ic of your denon amplifier.
Jan 07, 2009 | Denon AVR-1906 Receiver
I have a denon AVR-2105 when i switch it on using the On/Standby button which flashes RED it immediatly turns to a green flashing light and the system ignites only to be killed seconds later and the RED...
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Mar 11, 2008 | Audio Players & Recorders
Denon AVR-1508
sounds like overload protection
turn the volume all the way down, then turn it on
if that doesn't do it you may have a short in one of the speaker lines - try disconnecting them one at a time
Jan 13, 2008 | Denon AVR-1906 Receiver
How do you reboot the Denon AVR-2807 to factory settings
To reboot, turn receiver off by the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory. Enjoy this info is straight from Denon's Tech support. I had to do this on mine
Nov 25, 2007 | Denon AVR-2807 Receiver
272 people viewed this question
 Grubhead
Grubhead
