Question about Keurig B60 Coffee Maker
Lost instruction manual. How do I clean coffee maker to get rid of strong acid taste coffee? MoldelB60 single cup coffee maker
    Problem Solver:
  • 11 Answers
Most coffee pots are cleaned by running 1 part white vinegar and 1 part water. Just put in the reservoir and run a cycle. Once completed, run again with 1/2 pot of water only and it will clean it. If you use your pot daily, this should be done once every few months. If you have foul tasting coffee, you should use bottled water to rectify that. Plain tap water has minerals that dilute the taste of the coffee and over time build a residue in your pot.
Posted on Oct 09, 2010
How do you clean the coffee maker? My wife put vingar in it to clean and ran it through the coffee making process. Now...after running several cups of water through it we still have a vingar taste. ...
Lol! Your wife did the correct thing. (Hate to say it)Vinegar is acidic and eats away at all of the impurities that tap water leaves behind. To clear the vinegar, follow these instructions to a tee. Run one shot glass of bleach...yes bleach...through the unit. Follow this by two or three cycles of plain water. Your coffee will taste better than ever! And get this, bleach kills 99.999 percent of all bacteria known to man! Look it up! Hope this helps!
Jan 07, 2011 | Keurig Elite B40 Coffee Maker
How many scoops per cup?
Hi. normal is 2 scoops of coffee for 3 cups of coffee, then adjust from there for your taste. Good luck.
May 23, 2010 | Faberware FCP280 Coffee Maker
Coffee to water ratio
Weak coffee is 2 tsp per cup strong coffee is 3 tsp or 1 Tbls per cup. (3 tsp per Tblsp) 32 Tablespoons = 2 Cups, there are 4 Tblsp per 1/4 cup. If you're confused ( I am from reading my answer) Use 1 cup for weak coffee, two cups for strong or 1 & 1/2 for regular strength coffee. Hope that helps!
Apr 11, 2010 | West Bend (58036) 36-Cup Coffee Maker
Kitchenaid 14-Cup has plastic, chemical taste
Run 1/4 cup vingar with a pot of water. The coffee is not finishing its cycle and some remains in the works. You may have to do this several times. Washing the carafe with ice and salt by swirling it around a few times until it sparkels clean. Last thing for a good cup of coffee is filtered water which will keep the unit cleaner too. :)
Sep 18, 2009 | KitchenAid KCM400 Coffee Maker
Strong plastic smell and taste on a new Keurig Platnum coffee mak
I had the same problem and I discovered that after running 3 resevoirs full of water through the machine at 192 degrees , it got rid of the plastic smell. Set the cup size at the largest size mug and then just open the lid and close it , hit brew and let it fill the cup. Dump the water in the sink and repeat until you go through at least 3 resevoirs. The smell should be gone by then.
Sep 13, 2009 | Keurig B70 Coffee Maker
Coffee tastes like rubber / plastic - brand new Keurig Platinum - any suggestions?
After getting in touch with the Keurig folks - I tried their solution. And... it worked! The coffee this morning tastes wonderful! Here is what they said:
To get rid of the "new brewer taste", we recommend you flush three reservoirs of water through the system. Please add 2 tablespoons of white vinegar to the first reservoir of water. To do this, follow these simple steps:
~ Open and close the handle to simulate a brew cycle (without a K-Cup)
~ Press the largest cup size and brew a cup of water.
~ Repeat the process (opening and closing the lid, then brewing) until the reservoir is empty.
~ Flush two more reservoirs of water through the brewer in the same way.
This process will clear any lingering odors or flavors and allow you to enjoy an unadulterated cup of coffee.
Aug 19, 2009 | Keurig B70 Coffee Maker
Instructions for descaling Saeco Royal Digital
I used to run vinigar and water thru my coffee maker to remove the **** vinigar is slightly acidic. make sure run just straight water thru it afterward to get rid of the taste.
Robert
Sep 05, 2008 | Saeco Royal Digital Plus Coffee...
Lost manual need cleaning instructions
You can download the operating manual for your machine in pdf format right to your computer from www.bunn.com By the way, I wouldn't personally put vinigar in any Bunn machine, as it takes forever to run enough water through them to get rid of the vinigar taste.
Jul 15, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Coffee pot turns stops brewing in the middle of the cycle
Yup thats the Ticket - EASY FIX -
you have to clean the insides too people... lol.. The best way to do it is to buy citric acid crystals available from your local pharmacy. who knew huh? a couple of tablespoons in distilled water. Brew half the pot and let it sit for 30 min the brew the rest of the pot. Notice the color of your water after your done brewing. probably green from copper.. I could go into much more detail but thats the short answer... brew another pot or two of just plane ole water and bang your good go.. You should do this every month with any coffee pot for better tasting coffee..
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Keurig B60 Coffee Maker Logo
482 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
