Question about Craftsman 1 Bin Grass Bagger
Hello, my craftsman 13.5hp ohv rider will not start. The left front tire deflated here 1 week ago, so I left the mower in the back yard for 2 nights, which happened to be very cold with frost. After fixing the tire the mower will not start. Turning the key with gives me nothing, no sounds at all....please help
  • 454 Answers
Remove battery and bring inside. Let it set for a few hours to warm up, it may be partially frozen. If you have a battery charger, after it has warmed up fully, charge it at a slow rate (1A) overnight. Put it back in the mower and try again. If still nothing, the battery may be ruined.
Posted on Oct 09, 2010
I have a Sears YT 4500 Lawn Tractor. How do I straighten the front tires. One points left and one points right. I can't find an adjustment on the tractor
Craftsman makes a wonderful mower for the money. I've had 2. Until a couple years ago, however, they all had a huge problem - the front axles on these mowers were not cast-iron like the better, more expensive mowers. Accordingly, if you did something to put the front wheels/axle in a serious bind (like catch a tire on a good size rock or building corner with the wheels turned and while backing up and looking backwards), you may have seriously damaged the front axle. Sometimes that can be corrected with placing bushings in there if it's not too bad, but from what you describe it sounds like you've blown up the front axle. That's why your front wheels are going in different directions. Next thing: awful noises and inability to steer properly. I blew out front axles on 2 Craftsman mowers and repaired each of them before buying machines with cast-iron axles - Cub Cadet, John Deere. As I recall, about $235 each time.Got tired of it! The good news is that now Craftsman is putting cast -iron axles on most all of their higher end tractors. You'll need to have this done professionally if you want to keep or sell the machine. Then, go with a good, strong cast-iron axle. You can't adjust this problem. Sorry, friend. . .
Aug 08, 2015 | Sears Garden
My 5 hp MTD mower keeps stalling after running for a couple minutes. I then prime it excessively and it will start back up and do the same again. I have cleaned the carb and replaced the priming needle,...
You probably have already done this, but I had a JD 111 rider awhile ago and did most of the things you have done with no success. Then I replaced the fuel line and "BINGO" it worked great after that. Seems the line had a weak spot and would **** closed when trying to start.
Good Luck
Jul 10, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
I posted the below problem last night with the request for additional information reply sent 2 hours ago. I need to use this mower today. I need to have an answer. THanks Problem with the...
Thought I posted a solution earlier on this, but it was my first post and I don't see it here so I'll try again.
Google search on your model shows the drive belt diagram on page 27 of the manual.
link below:
http://www.mytractorforum.com/images/reference/dgs6500.pdf
Looks like mine.
basically need to remove front pulley by loosening center bottom bolt while holding the center nut on top of motor.
Slip belt over the rear pulley first and then straight toward the front, slip belt on front pulley and then slide pulley back onto shaft.
Then wind through the rest of the pulleys etc..as seen in the diagram.
Jun 08, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Hello I have a toro zero turn rider z4220 I think I bought it new about 2 to 3yrs ago when I was putting it up last winter the left drive would not go forward or reverse then shortly there after the right...
Hello, W/D here.
Look for a transmission disconnect rod, usually at the back of the tractor, about even with the top of the gearbox. If it has been moved to the out position, the transmission will not operate from the seat, but you can push it.
Good luck, --W/D--
Mar 17, 2011 | Toro Zero Turn Rider 74366 Lawn Mower...
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
We have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Apr 12, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Flat front tire need to remove from craftsman 13.5hp ohv riding mower
Remove the plastic dust cover, remove the E clip holding it on the spindle, remove the spacer/thrust washer, slide wheel and tire of
Sep 09, 2009 | Craftsman Garden
What type of oil does a OHV 17.5 HP Kohler engine; number of zerk
10w-30 oil. The only grease fittings I know of are on the front wheels and axles.
Jun 22, 2009 | Mtd 22" Yard Machine Push Mower
Craftsman 1 Bin Grass Bagger Logo
136 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
