Question about Motorola Mobility H670 Headset
I have set my bluetooth H670 up with an old phone. Now I purchased an Iphone and would like to hook it up to it but I dont have my pin. WHat do I do
    President:
  • 1,118 Answers
Try '0000' (four zeros).
Hope it works for you.
Regards, Carlos
Posted on Oct 09, 2010
HI. I have a Motorola H670 Bluetooth. I've used it with two phones so far. Today I upgraded to Iphone 4. I can't get the BT to reset no matter what I do (following all instructions found). ...
Your phone will find your headset only if it is in pairing mode. This mode is denoted by its indicator light steadily lit in blue at the time you slide the call button towards the microphone (i.e. turn it on). If the light is not steadily lit then, you must ensure that all devices previously paired with your headset have their bluetooth radios turned off and try again. When the light is steady, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on the list of found devices. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is succesful, your headset should enter the stand-by mode. There might be an indication on the phone that a headset is connected too.
By the way, if your headset's user guide happens to be missing ,feel free to download it from this location.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
May 16, 2011 | Motorola Mobility H670 Headset
Pin code for Altec Lansing iMT521 SoundBlade BT Speaker to pair wit iphone 3gs
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 18, 2010 | Altec Lansing T515 Portable Speaker for...
How do i pair motorola h670 with blackberry torch
Please kindly follow the detailed solution provided below;
STEP 1 Put on the motorola h670 by pressing and holding the switch button for 5secs,afterwards you will hear a click followed by a blinking of blue lights,by now the headset is in pairing mode.
STEP 2 Activate the bluetooth radio on your blackberry torch,by clicking on the menu>set up>bluetooth>search.
STEP 3. After searching,your torch will find the motorola h670 in the list of found devices.click on it,afterwards a message will display saying "pairing complete".
By now your blackberry torch has been successfully paired with your motorola h670 headset and you are good to go.
Take care!
Dec 05, 2010 | RIM BlackBerry Torch Cell Phone
Can not connect bluetooth to MY65T Navman
I've got MY65T working on an iPhone 3GS. I previously had the problem where it would pair and retrieve phone book, but not transmit or receive voice from my iPhone when making a call.
The last thing I did that fixed it was to remove the bluetooth pairings and "reinstall software on your navman". I don't know if this may remove some of your settings / POI / etc. This was a new purchase so I didn't have anything to lose.
Before doing this I had upgraded the navdesk software to 7.30, and installed the latest firmware for MY65T. Firmware is located at http://www.navmansupport.com.au/Software/My%20Series/MY65T/MY250___352.htm
Details:
-remove the phone bluetooth pairing from the Navman from Settings / Bluetooth / My Paired Devices / [your phone] / delete
-remove the bluetooth pairing from your phone's settings
-connect navman to PC and launch navdesk
-click "My Navman" / "Reinstall software on your Navman"
-download the install file if prompted
-accept the reinstallation prompts and complete reinstallation
-set your phone to discoverable over bluetooth (just keep it on the Bluetooth settings screen on iPhone)
-go to Settings / Bluetooth /" Search new devices" on your Navman
-click your phone's name on the navman's discovered devices
-enter the PIN onto your phone when prompted and accept the pairing. This takes a little while.
-test handsfree!
Nov 29, 2010 | Apple iPhone 3G
My 3GS iphone bluetooth headsets disconnect from the phone periodically and never use to. Solution? I even purchased a new headset, same problem.
Bluetooth on iPhone:
On iPhone:
1) Go to Settings
2) Go to Reset
3) Select "Reset All Setting" (Make sure you save passwords. Data is safe.
On Headset:
Clear all previous pairings.
Once iPhone reboots, turn on Bluetooth.
Nov 24, 2010 | Apple iPhone Smartphone
I purchased a head set a couple years ago and I am trying to pair it with my phone It was working with my old phone just last week. Pairing was successful but it is asking for a password. How do I find...
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Aug 23, 2010 | Jabra Bluetooth Headset with Adjustable...
How do I raise the volume on the Motorola Bluetooth H670?
simple raise the volume on the phone the blue tooth is paired and will go up automaticly
Apr 13, 2009 | Motorola Mobility Bluetooth Hands Free...
The blurtooth is not going into pairing mode. I was using this bluetooth (motorola h670) with another phone and I just changed the phone.
you will have to reset your bluetooth device first and then start pairing process with the new mobile.
thx
Feb 25, 2009 | Motorola Mobility H670 Headset
Motorola blutooth
the factory defualt pin is 0000
Sep 30, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h670 bluetooth
Manual Says 0000 but it does'nt work for me. Any other ideas anyone?
Mar 14, 2008 | Motorola Mobility H670 Headset
Motorola Mobility H670 Headset Logo
60 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
