Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
AFTER CHANGING WATER FILTER, THE REFRIGERATOR MAKES RUMBLING NOICE EVERYTIME WE GET WATER. WE HAVE ELITE KENMORE.. TYPE 26SSA MODEL NBR. 106.55616400
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Posted on Jan 11, 2009
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
rylee_smith
  • 8619 Answers
SOURCE: Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 03, 2009
  • 670 Answers
SOURCE: kenmore 106 89482995- How to replace water pump?
Access will be from the rear at bottom. Pump found at Sears website at this link. Love those helpful service people !! link is long, but it works. i used copy and paste http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=10689482995&productCategoryId=0164160&brandId=0582&modelName=AUTOMATIC-ICE-MAKER&diagramPageId=00003&componentDescription=PUMP&documentId=P0306093&backToLink=Return to Sub Components list
Posted on Jul 01, 2009
Can't close the door on the water filter cabinet on my Kenmore Elite refrigerator
check to be sure you have the correct length filter in place, you may have one to long for the unit.
May 30, 2015 | Kenmore Refrigerators
Have a Kenmore Elite Side by Side and there is water running down the side of the fridge which appears to be coming from the water filter. Already changed it twice.
Did you flush the system after changing the filter? Air can cause water to leak if it not flushed after each filter change. It takes about 6 to 7 minutes to get all the air flushed out. I hope that helps...
Nov 12, 2014 | Kenmore Elite Side By Side Refrigerator -...
Kenmore elite 596.735 .water leaking from rear of water filter unit.
What is the complete model number of your unit? Look inside the refrigerator section.
Oct 21, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Can't identify "water filter indicator light"
the indicator light could be on the control panel inside the refr section if your controls are there, or it is most likely on the front of the dispenser panel. it only comes on when you draw water from the dispenser and thats when you will see it be green, filter ok, yellow, filter at 80% life, or red, time to replace the water filter.
also you dont need to shut off the water when changing the filter as it is made with a shut off device in the filter housing already and is automatic.
by the way filters are expensive, go online and check prices. google "water filters" and find a good price.
Dec 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite - Interior water dispenser stopped working
Frozen water tank, some of these had an insulation kit that will prevent this from happening. Make sure you have water coming out of valve to tank, if so it will probley be a frozen tank. Make sure fridge is on factory settings. If it doesnt thaw out, check into the frozen tank kit...
Jul 14, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Bypassing a filter
They do make a bypass for this which you can get at http://www3.sears.com/.  Will need to know the entire model # from the sticker on the inside of the fridge.  If you have trouble let me know.  I would the the model # also to help further.  Also, it may say something about it in the owners manual.  Let me what you find.
Oct 17, 2007 | Frigidaire FSC23F7D Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
