Half of thr screen in my laptop is blank - Computers & Internet
Its screen problem
Posted on Oct 09, 2010
When printing my emails I only get only half the message, top part and the bottom half is blank.
Depending on which email service you are using, I.E. Hotmail, you may only be getting a screen shot of the email. In other words it will only show exactly what your seeing on your screen if you simply right click and print. Hotmail has a little ACTIONS with a downward pointing arrow on the right side of your screen. Click that and select print and it will print the actual message instead of a screen shot of the message. I have to assume other email servers use similar techniques to print the actual emails instead of just screen shots. Hope this helps.
Sep 17, 2014 | Dell Computers & Internet
Is it worth to buy part for screen for laptop or it can be fix? Plms with laptop is when i put laptop down n screen dropped half n top half is blanks n bottom half is blurring can see half of it.... help
The screen replacement is not cheap, hook a spare monitor to the video output usually on the back, if okay! the LCD screen is bad and must be replaced, if symptom is the same for both, it is the Video Graphics Card that is the problem normally built into the motherboard, If the laptop is a few years old I would opt to replace it.
Mar 13, 2012 | Samsung Computers & Internet
Laptop display only displaying the top half of the screen
Test it with an external monitor if it works fine then you will need to replace your LCD screen.
May 04, 2010 | Dell Latitude D600 Notebook
LCD Screen is normal on one half and blank on the other
Most likely. You can check the cable connection to the motherboard and check the cabel where it goes thru the hinge assy for wear, but what you describe is indicative of a hardware failure of the LCD
Also connect an external monitor, see if it shows full screen, if it does, and reseating the cable has no effect, check Ebay for a replacement LCD
Jul 04, 2009 | Acer Aspire 1800 Notebook
Sony ericsson Z310i blank screen
This just happened to me, the solution is to wiggle the top half a bit (like you wanna break it, but don't break it.) The root of the problem is a loose wire that connects the two phone parts. Mine still goes blank on me but then i wiggle it... just a little bit...
Apr 27, 2009 | Sony Ericsson Z310i Cellular Phone
When i shut my laptop the tv i use as my monitor goes blank.
Right click the power icon in the system tray (should look like a little plug with a lightning bolt on it.)  Click on "adjust power properties."  Click on the "advanced" tab, then where it says, "When I close the lid of my portable computer," select "Do Nothing."
Jan 25, 2009 | HP GX612AA Pavilion Media Center M8330F...
Laptop won't start up
make sure thr memory is installed correctly and securely
can you get into safemode
Jan 20, 2009 | HP Computers & Internet
Blank screen laptop
Your SONY should respond to the following:
Look for the blue FN key, hold it down (use it like a shift key)
While holding it, look for a key, also printed in blue with a picture that is half sun/half moon. On my laptop is the F8 key. As you press the key watch the screen to see if gets lighter.
Good Luck!
About Me:
Carl DeAlto
DeAlto Computer Solutions
http://www.dealtocomputer.com
Jan 17, 2009 | Sony VAIO K45 Notebook
Laptop screen
Hi and welcome to FixYa,
Offhand I would venture that your concern could possible be a backlight assuming your have a 17 inch monitor with 2 CCF lamps or the LCD display screen interface. Initially, if at all possible take a snapshot of the display with the half blank. The picture would have to be 150kb max though.
Pls post back as requested. Good luck and Thank you for using FixYa.
Jan 11, 2009 | Acer Aspire 7520-5185 Laptop
NO PICTURE
Turned the Tv seton had only half a screen tried to used the remote to reset the set to is regular settings it reset but the picture was offset to the right of the right of the screen I the brought up the menu in hopes of using the vertical or horizontal to bring it back full screen and the remote stop functioning for the tv and i put new batteries in it thinking matbe the remote was down but to no avail it still didnot work I had to unplug thr tv for about an hour and plug it back up for the remte to work and still had only a half of sreen and now i have sound and no picture just a green screen
Nov 15, 2008 | Televison & Video
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
