Helt on mt 882 router
Please help me to know, how to access the mt882 routers web ui?
  • snakysue Jun 10, 2008
    hi. i have just bought an azurewave router. I have tryed to install it, but when i connect to the internet and type in the ip address of Http://192.168.0.1, like it has instructed me to do, well then a box appears saying thats it requests a username and password to get in to it..
    could you please help
    Kind regards
    Amanda
Admin does not work
Posted on Dec 26, 2008
Well the pass should be admin and the pass should be password
Posted on Aug 08, 2008
I too have got the same problem. my old 520 worked from day one without this.
Posted on Jul 09, 2008
    Problem Solver:
  • 9 Answers
If you have not changed any configuration then this one wil do the work:
http://192.168.0.1
Regards,
Vakhtang
Posted on Jun 09, 2008
I need help with belkin n150 model F7D1401 V1 ..i can't connect to my network..i have a Huawei SmartAx Mt 882 modem..and i want to connect my network, wich is an ADSL one, to my computer..I can't...
Your MT 882 modem most likely has a DHCP Server that will interfere with the ip address of the router. Did you plug the Router directly into the laptop then go to dos prompt and type in ipconfig/renew . Or reboot the laptop !
Then type in 192.168.2.1 into browser
You need to work out the IP address of your 882 modem and then change the dhcp server leases on it to start at 20 like it might be 10.0.0.1 to 1.0.0.254 or it could be 192.168.1.1 to 192.168.1.254 .
if you are planning on using both devices on the network !
Make the Modem DHCP start at 192.168.2.20 to 192.168.2.254 and then make the Belkin router / modem ip address be 192.168.2.2 and the 882 modem 192.168.2.1 if you plan on using the two devices together on the network disable the belkin dchp server.
if you are using just the belkin then the reboot or ipconfig/ renew will be all you need .
Apr 25, 2017 | Belkin Basic Wireless Router
Need to put a password into a router that has been reset
If you install the cisco connect software to your computer, you should un install it first to have a better access on the web UI of the E1000,
you also need to reset the router, access UI, 192.168.1.1(default IP)
go to the wireless tab and configure the wireless setting,
if you have any problem with it call 1-800-326-7114
Feb 01, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I cannot access my WEP Hex Key, how can I locate it or reset it?
Connect to the router with an ethernet cable. Use a web browser and connect to 192.168.1.1 You should see a router home page. login as admin (default id= none/blank/null password=admin) These detailed instructions may help here http://nabtron.com/forgot-linksys-wrt54gr-password-how-to-reset-settings-of-the-router/180/ browse to the wireless/wireless security section and set up your WEP key. You can preview the web page layout here; http://ui.linksys.com/files/WRT54G2/ e.g. http://ui.linksys.com/files/WRT54G2/1.0.00/WSecurity.htm for you this would be http://192.168.1.1/WSecurity.htm
Jan 08, 2011 | Linksys WRT54G2 Wireless Router
I have forgoton my key words
If you forgot your password, we can actually access the router web ui.
Accessing the Router's Web-based Setup Page
Step 1: Open your web browser.
Step 2:Enter your router's IP address on the address bar and press the Enter key.
NOTE: The router's default IP address is http://192.168.1.1.
Step 3: The Enter Network Password window will then appear. Type your router's User name and Password. Click OK afterwards.
Web-based Setup Page Wireless Security Options
On the web-based setup page, you'll be able to see all of your router's wireless security features. Wireless settings wherein you can see your network name and once your click wireless security sub tab under wireless page you will then see your network key or password (passphrase).
Nov 05, 2010 | Linksys Wireless-G WRT54G Router
TalkTalk Modem Smartax MT882 to Netgear RP614 problem
Well your modem and router IP is same thats why you can't connect your router with modem
your have changed IP of the router,please follow steps to resolved your issue
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.0.1 address bar. press enter
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolved your issue
Happy to help
Thanks for using Fixya
Apr 04, 2010 | NetGear RP614 54 Mbps 4-Port Web Safe...
Request
it s eather 192.168.2.1 or 192.168.1.1 from the address bar
May 30, 2008 | D-Link DI 514 Wireless Router (DI-514)
Wlan key for netopia 2247NWG-VGX WIRELESS ROUTER
Hi there!
I believe the WLAN key can be found at your router's set-up page or web ui. Do you know how to access it? If Not, then try to access this link and hopefully this will help you to find it..
http://www.netopia.com/support/hardware/technotes/NQG_112.html
May 04, 2008 | Netopia 2247NWG-VGx Wireless Router...
Port forwarding
Hi!
Do you know how to access the router's web ui via Internet Explorer?
If it's the default then follow these steps:
1. Open IE then type http://192.168.1.1 (username: (leave it blank)/ password: admin)
2. Click at Applications and Gaming tab
3. Click at Port Forwarding sub tab
Hope this helps!
May 03, 2008 | Linksys Wireless-G WRT54GS Router...
Dificulty in configuring wrtg4g
There are three major steps to setting up a wireless router.
First set up WAN side access to the internet. For this you need information about your internet service provider. Please respond with your internet service provider's name or better yet a link to their help/support website.
I assume you already have access to configure the router at 192.168.1.1 if not please do the following. Open Internet explorer and enter 192.168.1.1 where you would enter fixya.com and press enter -- do web pages appear in your screen from the wired computer. If so we have manual access to configure the router. If not let me know.
Please reply with a response to this message.
Second we will test wireless connections to the router
Third we will secure the tested wireless connections to the router.
This process will require interaction and several iterations of instructions to complete. Please add a comment to this request with the necessary information if you with to proceed in this fashion.
Jan 01, 2008 | Linksys Wireless-G WRT54G Router
SmartAX MT882 Firmware Problem
Hi there!
I'll try and help you out with this but I need to ask you these:
1. Is the firmware of the MT880 compatible with the MT882? Have you checked their website for the correct firmware for the MT882?
2. Do you know how to access the routers web ui? If Yes, then try to go to Tools > Firmware Upgrade
Hope this helps!
Sep 12, 2007 | Computers & Internet
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
